Author Topic: Boot light flicker on dash, Intermittent interior lights and door sensor....  (Read 6808 times)
Offline shaunmorton
Strange one ive been having here. Wondered if anyone had experienced the same?
My MK4 AUM has been having these issues for about a year now becoming more often now.
Basically sometimes when i'm driving along i can see the boot light flicker on the dash. While this is happening the interior lights wont turn on.
At the moment if i give the relay box above the drivers footwell a push with my foot it will go away for a couple of minutes.
A more recent problem is that when i open the drivers door it doesnt sense that this is open. meaning it locks itself and the alarm goes off if the door isnt shut. The same time the rear O/S door lock has stopped unlocking..
I have checked all fuses/relays and the plugs on the CCM are pushed in tight..
I have checked the boot switch to see if the washer has leaked and i have checked the loom going into the boot through the rubber flexiboot..
This is driving me INSANE!!!
Anyone know anything else i could check?
2001 mk4 gti aum 1.8t
Longlife custom built non res cat back & k&n oem replacement
Offline itavaltalainen
Boot light is most likely broken wires in rubber grommet, next to boot hinge.
Driver's door not being sensed open is micro switch or wires in door grommet broken.
Rear lock may be faulty micro switch or mechanical fault in the lock itself.
If you have access to VCDS you can check micro switches without having to take locks out.
Offline Nino
  • Insta - F6UGA
As stated above for the boot, check this section...
You may find you have this issue...
If that is fine, I would say that you need a new boot module..
One of these...
As for your doors, sounds like you need new door modules
They look like this..
Current - MK6 GTi Edition 35 - Candy White - 3 door.
Offline shaunmorton
Cheers guys i'll try and find someone with VCDS to check those micro switches.
Are those door lock modules hard to replace because i seem to remember the inside of the doors was a nightmare when i went to replace the electric windows mechanism (which i got a garage to do in the end).
looks like all of these issues are a bad coincidence.... Annoying.
Offline lemski
  • 16v
Also good to check the connection on the boot latch for the boot. Another common thing.
Offline Mr_Orange
Dodgy door module/es will do this. I changed out boot latch and problem remained. Only figured it out by shutting driver door over and over again the warning light went out. Oh and it auto-locked me out the car one day.... :$
Build thread clicky
Offline shaunmorton
I nearly got locked out of mine when it hadn't noticed id opened the drivers door after unlocking.... Lucky the window was open.
Need to get on with it now before the cold weather arrives
