Author Topic: GTI FABRIC SEATS BACK PAIN  (Read 6785 times)
Offline SCOTTE
« on: 07 September 2016, 21:53 »
Hi all, Has anyone else had lower back pain from seating in the GTI seats for about an hour of driving? I seem to have had it twice now  :cry:
Offline monkeyhanger
Re: GTI FABRIC SEATS BACK PAIN
« Reply #1 on: 08 September 2016, 07:25 »
Have you adjusted the lumbar support?
Offline Talk-torque
« Reply #2 on: 08 September 2016, 07:27 »
No, never. Not the best seats I've had, but not the worst, by far.
Have you got the lumbar support pad thing adjusted out? Other than that, it's down to finding the best seat position and seat back angle. Worth spending some time just trying different arrangements, until you find one that is most relaxed.
Could also be that you're a bit tensed up, driving a new and special car.
Roger.
Offline vidman2
« Reply #3 on: 08 September 2016, 09:19 »
I used to have back pain - I have osteoarthritis - and have found using a CG Lock to hold me in place makes a huge difference.
In my last car I had a MED design  'Backfriend'  which also helped a lot.
But as above do try the lumbar adjustment and also make sure you have the seat and wheel adjusted properly as they will cause no end of problems if not set correctly for you, remember the seat goes up and down as well as back and forward as does the wheel.
2015 R DSG. Limestone Grey, DCC, Winter Pack, Tech Pack, Reversing Camera    plus   2013 Mk7 GTi DSG - Performance, Navigation, Winter Pack, DCC, Park Assist,
Offline fredgroves
« Reply #4 on: 08 September 2016, 09:24 »
Yeah something not right. I've found it the most comfortable car I've driven in years actually.
Have a fiddle with the setup, especially the lumbar support and try adjusting the steering wheel distance to get your arms and legs in the right place - you might be over reaching or something.
Are you especially tall or have short legs?
mjh_056
« Reply #5 on: 08 September 2016, 09:30 »
My wife had prolapsed disc from accident many years ago and the Audi seats used to set her twinges off quite readily, however the last 3 years with the GTD she has not complained once and in fact after we have been walking the return to the GTD and the heated seats is seen as a form of therapy.
Another reason we stayed with the MK 7 that forgot to mention, as she made it pretty clear in the Audi garages that the Golf was her preferred car.
Drove to Lake District recently on a near 5 hour journey and got out as fresh as could expect outside of a true luxury cruiser.
Not sure if the DCC aids this? as obviously you get no crashes or anything like that which would jar the back
But one of things which is a plus, well supported with no sideways movement, comfortable and with the heat added,  even therapeutic :)
Think all the elements are there for the comfort, so its getting the seat set up correct for posture maybe?
Offline buddfridge
« Reply #6 on: 08 September 2016, 09:59 »
Yes I have had back pain from these seats, I also have a disc problem but when I did adjust the lumber support it was better, its not the best driving seat I came from a gt86 and that seat was fantastic at supporting the lower back but now I am use to it I can manage ok.
« Last Edit: 08 September 2016, 10:56 by buddfridge »
gti pp manual white 5 door
mjh_056
« Reply #7 on: 08 September 2016, 10:08 »
Yes I have had back pain from these seats, I also have a disc problem but when did adjust the lumber support it was better, its not the best driving seat I came from a gt86 and that seat was fantastic at supporting the lower back but now I am use to it I can manage ok.
Back pain as sure you know is complex, as what may trigger one person, may not for another depending on so many variables of the location of the injury and how relates to posture when sitting.
So it will be sometimes the perfect seat for some, but actually aggravating for another - basically for the more complex of back conditions it does go beyond standard seat design
Offline Watts
« Reply #8 on: 08 September 2016, 14:34 »
When I first got mine I adjusted the lumbar giving maximum support and was getting achy on long journeys. Took it down to it's midpoint and still some issues so now it's fully off and my back has been fine since.
Previously:
Offline kalimon
  • My other car's a van
« Reply #9 on: 08 September 2016, 15:16 »
A lumbar support is almost guaranteed to f%#k your back up if adjusted anywhere near fully out.
I find my GTI seats to be very comfortable apart from the side bolsters digging into my enormous lats........
5 DR Mk 7 GTI PP
