Author Topic: drop links  (Read 1920 times)
Offline crazydog
drop links
« on: 06 September 2016, 20:30 »
hi guys probably this has come up before,but here goes.with adjustable drop links does the link need to be shorter or longer to give more clearance to the driveshafts,assuming not having gone wild with the lowering.    cheers.
Offline lemski
  • 16v
Re: drop links
« Reply #1 on: 07 September 2016, 07:36 »
Longer to keep the shaft clear of the rollbar as it goes ovee the top. (its been a while since ive went under a mk4)
Offline crazydog
interior light switch
« Reply #2 on: 19 September 2016, 17:01 »
Hi guys need more help the interior light switch has somehow come loose in the overhead panel igot the cover off that contains the key to wind back the sunroof in emergency,a small spring came out with the cover so i assume this is part of the switch being loose,if i hold the inside of the switch and the sliding part together it still works ,the problem is i can't see how the switch panel comes out see what holds the switch in place. cheers any ideas welcome.
Offline crazydog
Re: drop links
« Reply #3 on: 20 September 2016, 18:47 »
lengthened the links and it was terrible grinding ,shortened them and all worked fine,looks like shortening solves the problm, thanks anyway
Offline lemski
  • 16v
Re: drop links
« Reply #4 on: 20 September 2016, 19:25 »
50 percent chance. Been a long time like I said
