Author Topic: warm start 95 vr6  (Read 1395 times)
Offline golf1.8t
warm start 95 vr6
« on: 30 September 2005, 00:30 »
when i start the car first its fine but when it warms up it can be a pig to start you would have to turn the key for about 5-10second before it will start any body else had this problem or knows what it could be thanks.
DUBBIN FOR LIFE:
Offline DUNNY
Re: warm start 95 vr6
« Reply #1 on: 30 September 2005, 20:55 »
YEP I HAVE ITS A RIGHT PAIN IN THE ARSE BUT QUICK AND EASY TO FIX ITS THE COOLANT TEMP SENDER HOPE THIS HELPS
 STEVE
Offline golf1.8t
« Reply #2 on: 30 September 2005, 23:50 »
the sensor in the expansion bottle if so have you done yours is it ok now thanks for your reply
DUBBIN FOR LIFE:
Offline DUNNY
« Reply #3 on: 01 October 2005, 13:37 »
hi no its not that 1 its the sensor at the front of engine that all the pipes run to
it sorted mine straight away only cost me £22 hope this works
Steve
Offline golf1.8t
« Reply #4 on: 01 October 2005, 19:02 »
the 2 in the thermostat  housing think there blue and white if im right which one blue or white i will have i look but could only see them two sensors.
DUBBIN FOR LIFE:
Offline DUNNY
« Reply #5 on: 01 October 2005, 19:28 »
it should be the one at the top the one that was changed on mine  hope this helps good luck
Steve
