Author Topic: Fog lights as turning lights  (Read 3719 times)
Offline mwad gti
« on: 23 August 2016, 21:49 »
Hi all.
I'm considering getting my fog lights coded so that they work as turning lights. I know that it's not for everyone. I had turning lights on my last mk6 GT and found it useful.
Has anyone done this on their GTi?
Anyone know the code on Vagcom or whatever it's called now ?
2019 3 door manual GTi Performance in black
Bought 2 years ago as a 1 owner car, FVWSH and 10k miles
It’s a keeper
Offline SunnyGTI
Re: Fog lights as turning lights
« Reply #1 on: 23 August 2016, 22:04 »
Yep! Got this on my GTI. Easy to do if you know a guy with VAGCOM or VCDS...?
Definitely looks cool to me haha
Offline mwad gti
« Reply #2 on: 23 August 2016, 22:12 »
Cheers Sunny. Car is going in for a service soon so will prob get it coded then. Hopefully he can do it quickly if he knows the code.
Just thinking the turning lights are a good idea, they were useful on the last mk6 and I never knew until recently that they could be coded to the fog lights
It’s a keeper
Offline dubber36
« Reply #3 on: 01 September 2016, 08:29 »
You can also code them to come on when reverse gear is engaged. It sounds odd, but my B7 Passat does it as standard, so I coded the Golf to do the same. It does help, as it illuminates the wide areas where the front of the car may swing into when reversing.
Offline mwad gti
« Reply #4 on: 14 September 2016, 21:00 »
Fog lights coded in.
Glad I done it
It’s a keeper
Offline mwad gti
« Reply #5 on: 16 September 2016, 17:03 »
Look like mine are only comming on if I have the headlights switched to on and not whilst on auto
It’s a keeper
Offline SunnyGTI
« Reply #6 on: 16 September 2016, 21:45 »
Mine work when on Auto as I leave switch on Auto
But try resetting the coming home light function on the info computer. As I did that once when my fog lights were only coming home with headlights to On
Hope that makes sense...!
Offline The ANT
« Reply #7 on: 17 September 2016, 07:10 »
Leave the headlights on constantly, i do. It makes you more visible on the road. They go off when you get out of the car. That would solve the problem wouldn't it?
Suffering from a severe and unforgiving case of GTItis
