Author Topic: Central locking module bolts  (Read 3250 times)
Offline douglas
« on: 07 August 2016, 00:10 »
Hi... What type and size of driver is required to take out the bolts that secure the locking mechanisms on my mk4 golf? 40 torx is too small, 45 too big. Is it even a torx?! Also, where can you get a hold of replacement bolts...
Offline itavaltalainen
Re: Central locking module bolts
« Reply #1 on: 07 August 2016, 10:53 »
Locking mechanism? Door locks all Torx I think?
XZN screws me thinks though..... replacements should be obvious: VW.
Offline Bandit127
« Reply #2 on: 07 August 2016, 16:08 »
It is M8 XZN. About £10 on ebay.
Based on bitter experience you can get a torx bit and a regular Allen key to fit the head close enough to think it is worth trying, but that ends in tears. They are tight. They are hard too so if you strip the heads they are a bugger to drill out.
You need the tool - accept no substitues or bodges.
Offline birch
« Reply #3 on: 08 August 2016, 08:12 »
The bolts have M8 12point heads. search EBAY for 'M8 SPLINE BIT 12 Point Socket'.
Offline SafferYork
« Reply #4 on: 08 August 2016, 10:55 »
I drilled all 4 of mine out just yesterday, using a bolt extractor bought from Screwfix - 5 Pounds for the bolt extractor.
And still having issues with my locking modules  :angry:
« Reply #5 on: 08 August 2016, 20:05 »
What are the issues?
Offline douglas
« Reply #6 on: 08 August 2016, 23:04 »
I had the same bitter experience just a few days ago!!!
