Author Topic: Speedometer and fuel gauge problem  (Read 9357 times)
Offline hardmonkeys
  • Moderator
« on: 16 July 2016, 20:48 »
Since I've replaced the loom in my cabrio,I've had a problem with the speedo not working...and the fuel gauge not settling on a position...it goes up, then sprodically drops before going back up again...I'm not too concerned about that for now, it's speedo prob that is more important at the minute, I have checked VAGCom and nothing is coming up...
Been reading about a speed sensor on top on the gearbox? Is at the back?
If so, mine spins...from the top, if I took the connector off, then I can spin it...?
Also, on top of that isn't a 10mm bolt, so maybe it's not..any ideas??
Thanks
'05 VW Golf Mk V GT TDI Laser Blue
'98 VW Golf Mk IV GTi Black
'97 VW Golf Mk III GTi
'58 VW Golf Mk V GT Sport TDI Steel Grey
'10 Audi A4 B8 SE Multitronic
'00 VW Golf Mk III.V Cabrio
'12 Audi A5 S Line Black Edition
'0 VW Golf V6 4motion
MK3.5 Cabrio 2.0 8v Automatic to 2.0 16v Manual Conversion Project
http://www.golfgtiforum.co.uk/index.php?topic=272728.
www.dorsetautorestore.co.uk
Offline lemski
  • 16v
Re: Speedometer and fuel gauge problem
« Reply #1 on: 17 July 2016, 09:30 »
Maybe that speedo is the problem. I cant remeber but Im sure theres a 19mm holding the top of the sensor I. So you can spin it off and see if its still in one piece
Offline hardmonkeys
  • Moderator
« Reply #2 on: 17 July 2016, 10:49 »
I'll have another look later, but the only thing that seems to be holding it in, is that thing in the middle of it.. Got a bloody shed to put up today, then back to work tonight...weekend goes to quick lol
Offline lemski
  • 16v
« Reply #3 on: 17 July 2016, 12:45 »
True, from what I remeber of them gearboxes that top bit should be on a thread into the bottom bit of the sensor. 19mm or 21mm I think. Youd be able to feel it
Offline hardmonkeys
  • Moderator
« Reply #4 on: 18 July 2016, 00:19 »
Yes, you were right,  I managed to get it off, the top bit came off, and I have a small square spindle inside,
The other bit, that the spindle went inside, was in the box...sound right? Will get pic tomorrow(later depends on which way you look at it(btw way, since my last msg I'm still up, I'm now at work on the night shift, so not only have i tried to fix the car, put a shed up and tidy the garage, I am also travelling to and delivering around London lol. Might get to bed around 6am)) i tried to remove it, but it wouldn't budge!
Sound right??
Thanks for your help
Offline lemski
  • 16v
« Reply #5 on: 18 July 2016, 08:51 »
Yes mate sounds spot on. I think theres a 10mm holds the bottom bit in. Really cant remember. 5 years since ive taken a speedo sensor out
Offline hardmonkeys
  • Moderator
« Reply #6 on: 18 July 2016, 13:58 »
Does this look right?
https://imgur.com/R1SglPc
https://imgur.com/EIniufG
There doesn't seem to be any nut/bolt holding that in, I've tried to scrape away as much muck as possible.
I've also connected a drill to the spindle and recorded the speedometer unit in the car...nothing!
Tried using the previous cluster before I did engine swap, still nothing.
Offline lemski
  • 16v
« Reply #7 on: 18 July 2016, 19:17 »
Cant see in the hole but the other piece looks correct.
If its not recording maybe its f**ked. Unless it has to be in gear. Shouldnt think so though
Offline itavaltalainen
« Reply #8 on: 18 July 2016, 20:25 »
Have you put the speedo into test mode (yet)?
Offline hardmonkeys
  • Moderator
« Reply #9 on: 19 July 2016, 13:20 »
If this is the test mode,
https://www.gsfcarparts.com/community/index.php?topic=5964.0
then yes, I found this on Saturday whilst having a good scout around the Internet... When driving it doesn't register anything.
