Author Topic: Brembo Front brake disc's/Pad's. Any good??  (Read 3273 times)
RC81
« on: 15 July 2016, 20:45 »
Hi, I'm the look out for better braking on my 1.8T. The front discs & pads are fairly new but crap to say the least! It fails to brake enough above 80mph! With it being modded etc. So my first thought was the common larger diamater brakes from an S3, Seat Loen etc, but current funds won't stretch to that, so I looked through eBay and found these.
Are these any better than the standard 1.8T OEM setup
http://www.ebay.co.uk/itm/VW-GOLF-MK4-1998-2004-BREMBO-DRILLED-GROOVED-FRONT-BRAKE-DISCS-FRONT-BREMBO-PADS-/251338689243?hash=item3a84f40adb
Offline lemski
  • 16v
Re: Brembo Front brake disc's/Pad's. Any good??
« Reply #1 on: 15 July 2016, 21:05 »
Theyll be am upgrade to standard.
Im sure for 312 upgrade its just carriers, discs and pads.
Sure the callipers are the same
RC81
« Reply #2 on: 15 July 2016, 22:06 »
Cheers for the advice buddy. So if I was to go for (find) carriers, discs & pad's to suit a 312 setup but use my current calliper's, what exactly would I look for? Seat Leon, Audi S3, Golf MK5 GTI etc?
Cheers  :smiley:
« Last Edit: 15 July 2016, 22:10 by RC81 »
Offline lemski
  • 16v
« Reply #3 on: 15 July 2016, 22:48 »
Audi s3 is 312.
Sure the leon cupra are only 288 standard and the cupra r is a massive upgrade
Mk5 not sure on size. Disc wise its the wrong stud pattern
Offline lemski
  • 16v
« Reply #4 on: 15 July 2016, 22:54 »
The leon cupra may actually be 312 standard. (learn something everyday)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #5 on: 16 July 2016, 22:19 »
Leon Cupra is 312mm fronts as standard :wink:
Offline Dalo Harkin
« Reply #6 on: 22 July 2016, 11:32 »
MK1 TT is also 312 carriers
Offline andy68
« Reply #7 on: 22 July 2016, 21:49 »
MK1 Octavia VRS are 312 long as you dont mind them in green
