Author Topic: GTD Viewing  (Read 27811 times)
Offline stevw1
GTD Viewing
« on: 12 July 2016, 11:06 »
Hello Ladies / Gents
Had many VW's over the years. Looking at a MK6 GTD 09 DSG 61K.
What am i looking for in particular ??
Thanks for the advice  :wink:
Offline golfhappy
Re: GTD Viewing
« Reply #1 on: 13 July 2016, 01:29 »
Pretty much bullet proof, but due to what the mileage is probably water pump timing belt etc. Would be nice to have led rears but probably not as to the early year.
Audi S1 gone, awaiting 1.5tsi r-line, pan roof, led lights front and rear, active dash, 18" jurva alloys and a dealer fitted Oettinger roof spoiler in tornado red.
Offline SRGTD
Re: GTD Viewing
« Reply #2 on: 13 July 2016, 18:22 »
I had my mk6 GTD for nearly 5 years before I sold it. It was pretty much faultless, and probably the best car I've owned.
As the GTD you're looking at has got a DSG gearbox, check that the gearbox service was carried out at 40k miles. Not certain at what age / mileage the cambelt should have been changed on an '09 GTD - think it's either 4 or 5 years, so it should have been done on a 6-7 year old GTD.
Check the diamond cut alloys for for kerb or whiteworm corrosion damage; diamond cut alloys are quite prone to whiteworm if the lacquer is damaged and water gets under the lacquer surface. It'll cost £80-£90 plus VAT per wheel to get a decent refurbishment done. Also check the rear tyres for sawtooth wear on the inside edge; if present (you should be able to feel the 'stepped' pattern to the tread if you run your hand around the inside edge of the tyre), this could indicate an alignment problem.
If it's got leather trim, this can get a bit 'saggy', especially on the right hand bolster on the driver's seat. If it's got cloth trim, check the right hand bolster on the driver's seat backrest for wear.
You've not said what the spec of the car is, but there are some options that are worth having;
- leather, but see above re. possible sagginess.
- xenon headlamps; these were an expensive option and not many GTD's had them but they are very good.
- RNS510 or RCD510 headunits. Both of these are touchscreen (first one has sat nav, the second has a 6 disc CD changer).
- Bluetooth, this is a fairly easy retro-fit if it hasn't got it.
- Dynaudio sound system.
Good luck; hope the car you're interested in is a good one, but remember, there are plenty more out there if it doesn't meet your expectations.
Gone but not forgotten;
2016 Polo GTI; Blue Silk
