Author Topic: Indicator going nuts when turning left only (Fixed)  (Read 4262 times)
Offline InsightMusic
This seems like the last piece of the puzzle, but it's real confusing!
Only started happening last week and when I turn right the indicators work fine, all bulbs working, fuse changed..
The issue is when I indicator left only. It buzzes in the fuse box and the light on the dash either doesn't come on or is solid green.
I thought maybe the relay could need changing, but the indicators work perfect if I'm turning right..
Next suspect is the actual indicator stalk.
Anyone had this issue before in the past?
Any help would be greatly appreciated.
Thanks,
Stefan
« Last Edit: 15 August 2016, 16:18 by InsightMusic »
Offline sparkplug
Re: Indicator going nuts when turning left only
« Reply #1 on: 11 July 2016, 13:29 »
do the lamps all work ,if you use the hazard switch ?
1986 GTI atlas grey
« Reply #2 on: 11 July 2016, 14:14 »
Yep, all lights work with the hazard switch on.
Offline sparkplug
« Reply #3 on: 11 July 2016, 16:28 »
yeh I would try another indicator stalk then
1986 GTI atlas grey
Offline Brighouse-gti
« Reply #4 on: 11 July 2016, 21:01 »
Do you have any relays behind the headlamp on your car? Mine does, and when something similar started happening to mine it turned out to be earth wire to the relay.
« Reply #5 on: 12 July 2016, 09:21 »
Hey guys, thanks for your help so far.
I noticed today that if I hold the stalk in when indicator left, it works! However it's not very safe on the roads..
New indicator stalk purchased yesterday, which I am certain is the culprit.
Will update the thread once I've fitted the stalk.
Thanks!
Offline bgbazz
  • If it aint broke...I can fix it!
« Reply #6 on: 12 July 2016, 19:06 »
Maybe you could try this, before outlaying for a new stalk...give the whole thing a good clean, spray on a decent application of electrical contact cleaner...wait a few minutes and then wash all the crap away with a a really good dose of WD40. When it stops dripping, dry up everything you can see and apply some non conductive grease (white) to all the moving/parts you can see and get to (a cotton bud is good for this bit).
It will help if you have, or have access to, an air nozzle...makes the job much faster....it's worked for me over a dozen times on various vehicles.
Mk4 Golf TDI Estate 4Motion, remapped 1.9. Sweet runner = keeper. She is the 66th vehicle I've owned and hopefully, the last.
« Reply #7 on: 10 August 2016, 17:53 »
Hi again,
Tried all sorts of cleaning and dusting checking all connections/cables.. Nothing worked.
Replaced the indicator stalk and now it works flawlessly! Was only £10.00 off eBay.
Thanks for your help,
Stefan
