Author Topic: Maf problems  (Read 2436 times)
Offline sharki786
  • GOT BOOST??
Maf problems
« on: 06 July 2016, 20:34 »
Hi all. Its been sometime. Hows everyone? I need some help. I was cleaning my maf and i then managed to brake it. Anyway if i connect it and when the car boosts i get a violent boost cut. So i fitted a "working one" and now the car starts then cuts out (keeps repeating) if i disconnect it and then start the it runs no prob but just runs abit rought every now again but dont cut out. So i just ordered another 1 and its doing the same (car starts then cuts out straight away)
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline Dalo Harkin
Re: Maf problems
« Reply #1 on: 08 July 2016, 08:35 »
do you have a fault code reader?
you might need to clear the fault manually, it should have sorted itself out but not always
Offline sharki786
  • GOT BOOST??
Re: Maf problems
« Reply #2 on: 08 July 2016, 11:07 »
Done that plenty of times mate. I bought another 1 and same fault. If i put the original 1 back on the car runs fine i just get a violent boost cuts.
*****MK4 GTI T*****
Offline Dalo Harkin
Re: Maf problems
« Reply #3 on: 08 July 2016, 12:35 »
Have you checked the connector plug itself? check nothing is broken and check the wiring
Offline sharki786
  • GOT BOOST??
Re: Maf problems
« Reply #4 on: 11 July 2016, 22:10 »
I just got another 1 and i checked it and its still doing the same. I gota feeling that its the wiring. How can i check the wiring and the connector mate?
*****MK4 GTI T*****
