Author Topic: Puncture  (Read 4480 times)
Offline phil_790
Puncture
« on: 02 July 2016, 20:58 »
Hi all,
It's been a while since I posted, but I am away this weekend and got a puncture towards the edge of my factory fit bridgestones on the rear passenger side. I don't know if it can be repaired, if the tyre needs replacing and I can't get another potenza, should I replace both tears or is it alright to get one done. The car is a pp gti wit about 5500miles so there is quite a bit of life left in them...
Cheers,
Phil
Offline buddfridge
Re: Puncture
« Reply #1 on: 02 July 2016, 21:11 »
Why not use the foam for a couple of days so you can find the right tyre....good luck
gti pp manual white 5 door
Offline phil_790
Re: Puncture
« Reply #2 on: 02 July 2016, 21:15 »
At the moment it doesn't seem to have dropped pressure and it didn't bubble up when I put some liquid on it. I only noticed the head of the screw in the sunshine. Have got a 100mile drive home tomorrow and can't really do that on the space saver :-( what a pain!
Offline Booth11
Re: Puncture
« Reply #3 on: 02 July 2016, 21:28 »
How close to the sidewall is the puncture?   Replacing just the one tyre will be fine.
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline buddfridge
Re: Puncture
« Reply #4 on: 02 July 2016, 21:30 »
I would take the chance and try getting home before getting the tyre looked at, just reduce your speed a little.
Offline phil_790
Re: Puncture
« Reply #5 on: 02 July 2016, 21:30 »
It's just in the edge of the outer most groove, hopefully can be repaired. If I can't get a Bridgestone will it be ok to have a different tyre, I don't really want to skimp on cost, but it would be waste to replace both.
Offline The ANT
Re: Puncture
« Reply #6 on: 02 July 2016, 22:37 »
It's not ideal to have a newer tire on one corner but it's not the end of the world.
Suffering from a severe and unforgiving case of GTItis
Offline monkeyhanger
Re: Puncture
« Reply #7 on: 02 July 2016, 23:00 »
The car will be making corners all the time as that non-Bridgestone replacement will undoubtedly have far more grip than the other 3 tyres.  :whistle:
Offline corgi
Re: Puncture
« Reply #8 on: 04 July 2016, 08:54 »
If it is that close to the edge then it should not be repaired. I would always fit tyres in pairs, there could be a significant difference in grip across the axle even with a new and part worn tyre of the same compound.
Corgi
Offline Watts
Re: Puncture
« Reply #9 on: 04 July 2016, 14:28 »
I'm probably being a bit dense here but you say it's a puncture but it's not losing air nor bubbling when covered in liquid. So how is it a puncture? Just take it to a reliable garage for an assessment.
Previously:
