Author Topic: Front wheel bearing  (Read 2696 times)
Offline WeekendMechanic
  • Golf MK3 GTD
Front wheel bearing
« on: 25 June 2016, 10:26 »
Hi so my left front wheel started to make a howling noise, when I turn right noise goes away, I`m going to rotate the tyres to make sure it still makes the noise If so I will be buying new bearing.
My question is do I just buy the bearings or do I have to replace both hub and bearing,keep in mind this is the first time they would have to be changed as car has 122500 km?
Offline lemski
  • 16v
Re: Front wheel bearing
« Reply #1 on: 25 June 2016, 11:54 »
Hubs should be fine unless the bearing has workln the hb. Normally only happens when bearings have been driven on for a long time whilst being past it.
Last one I remember it felt like wheel was falling off and the hub needed replacing.
  • Golf MK3 GTD
« Reply #2 on: 25 June 2016, 12:54 »
Ok thanks a lot really apreciate it. :smiley:
