Author Topic: 17704 Error Code  (Read 3109 times)
RC81
17704 Error Code
« on: 12 June 2016, 11:08 »
Hi, I thought i'd connect VAGCOM to my 2001 Golf 1.8T (AUM) due to the temp gauge hovering between 70 -90 degree's during normal driving conditions.
So VAGCOM produced this code
17704 - Error in Mapped Cooling System (check Temp-Sensor and Thermostat)
            P1296 - 35-10 -  - Intermittent
I also looked through the mk4 maintenance + info section and found a thread which covered similar codes but not this particular one.  The car also starts, boosts and goes as usual with no issues.
Just takes a while to get warm in the mornings.
So would I need a new temp sender or thermostat?
cheers guy's
Offline yougy
Re: 17704 Error Code
« Reply #1 on: 12 June 2016, 12:39 »
fit a genuine temp sender dude
thats fooked it
Offline Mr_Orange
« Reply #2 on: 12 June 2016, 19:33 »
Thermostat ;-)
Build thread clicky
RC81
« Reply #3 on: 13 June 2016, 11:02 »
Thanks guy's, you've probably confirmed my thought on that one.
I've just ordered an Elring rocker cover gasket set first. Present one is allowing oil to leak  :sad:
