Author Topic: MK3 Sunroofs  (Read 3013 times)
Offline spud72_uk
MK3 Sunroofs
« on: 11 June 2016, 08:37 »
Doe anyone know what other sunroofs ( sliding glass ) fit a 93 MK3 Golf as not a lot of MK3 Golf ones out there - thanks
Offline gasketface
Re: MK3 Sunroofs
« Reply #1 on: 11 June 2016, 16:58 »
Are you looking to replace a damaged one ?.If so there are loads of used units available but there are 2 different types.They use a different sliding inner panel depending on year.
I have 2 late model one's here somewhere,P and R reg versions. :whistle:
Offline spud72_uk
Re: MK3 Sunroofs
« Reply #2 on: 26 June 2016, 10:36 »
Thanks - got 2 broken ones on both the same bit has broken ( the metal ali slider on the left hand side ) so cant even make 1 good one out of 2. They slightly different to each other so guess one early & one later one.
Trying to find something cheap locally as the car isn't worth a lot but the headlining is out still so not useable.
