Author Topic: Climate Screen Retro Fit?  (Read 5210 times)
Offline R32 Mad
« on: 05 June 2016, 13:34 »
Hi all, Is the climate screen retrofittable for the MK7 Golf GTI?
« Last Edit: 05 June 2016, 13:38 by R32 Mad »
Offline Brenbo
Re: Climate Screen Retro Fit?
« Reply #1 on: 05 June 2016, 14:49 »
Actually another way to look at this enquiry would be to ask if the climate screen were chipped, damaged or cracked could it be replaced by a third party/retro-fitted or does it have to go back to VW to have the windscreen refitted?  If it does have to go to VW to be refitted as I feel may be the case would it be part of the factory warranty if the windscreen were chipped 7 cracked?
However if it can be retro fitted it would be easier to replace the windscreen should it become damaged.
Offline iandjm
« Reply #2 on: 05 June 2016, 15:54 »
I would imagine a windscreen supplier could replace one of the screens as its more than likely a push on connector on each side feeding the supply to the screen.
2017 MY Golf R 3dr DSG | Lapiz Blue | Dynaudio | Heated Screen | Advanced Phone | Sat Nav | Winter Pack
Offline TwoSheds
« Reply #3 on: 05 June 2016, 16:21 »
If we are talking about 'retrofitting' rather than just replacing an existing climate screen then there would need to be wiring/connectors and switchgear present to operate the climate screen when fitted.
As its a factory option tied into having Advanced Telephone preparation as well I wonder how or maybe it has no relevance at all, to fitting a retrofit Climate Screen if you are not bothered about potential poor phone signal strength because of the screen makeup.
Offline mcmaddy
« Reply #4 on: 05 June 2016, 16:51 »
Do you still have to have the phone prep with the climate screen?
Offline TwoSheds
« Reply #5 on: 05 June 2016, 17:14 »
Just checked configurator and its still showing need to have advanced phone prep with the climate screen option.
Offline Bungleaio
« Reply #6 on: 05 June 2016, 18:53 »
Anything is retrofitable providing you can find the right person to do it.
Abarth 595 Turismo + Classic Mini + Triumph Street Triple RS
Did have 3door DBP GTI PP
Offline mcmaddy
« Reply #7 on: 06 June 2016, 20:14 »
The configurator has always said both together but hasn't someone on here ordered the climate screen without the advanced tel prep?
Offline peterdoherty
« Reply #8 on: 06 June 2016, 23:28 »
Think youre thinking of a member from Ireland where they can be specced separatley
MKVII GTD DSG Carbon Grey 5DR, Dynaudio, Keyless Entry, Rear View Camera, Colour MFD, Park Assist, Winter Pack, Climate Screen, Advanced Phone Kit, High Beam Assist
Offline mcmaddy
« Reply #9 on: 07 June 2016, 06:58 »
Ah ok. It wouldn't surprise me if we can do this but would need the salesman to do it on ordering.
