Golf mk2
Replacing Hubs
Topic: Replacing Hubs (Read 3591 times)
th3_f15t
Replacing Hubs
30 May 2016, 22:29 »
Can you use the hub carriers (uprights) from an early mk3 Golf on a 16V with 256/280mm brakes?
Looking at this on eBay -
http://www.ebay.co.uk/itm/191878282605
Looks identical to the hub's I have but far less than the mk2 16V advertised ones.
Moving over to Flickr, sorry for the broken picture links!
lemski
Forum addict
16v
Re: Replacing Hubs
31 May 2016, 00:09 »
Yeh. You can use tdi ones if you can find them aswell.
Failing that mk3 gti hubs and use the bottom.joint aswell as its a different design
th3_f15t
Re: Replacing Hubs
31 May 2016, 09:04 »
Oh, so the mk3 ball joint fits to the mk2 wishbone without issues?
lemski
Forum addict
16v
Re: Replacing Hubs
31 May 2016, 11:28 »
Yeh same 3 bolt pattern just the ball joint to hub is different.
Golf mk2
Replacing Hubs
