Author Topic: Thoughts?  (Read 5333 times)
Offline jonesltd
  • MK7 R
Thoughts?
« on: 22 May 2016, 17:40 »
Decided to keep gtd, got cambelt done etc and want to sort my ride out like I did with the mk4 (subtle touches)
Need to get coilovers...anyone thoughts but cannot spend a fortune I had fks on mk4 think 169.99 I paid and lasted for years...ride was hard but got used to it and thought it was the norm.
What about these as well I had h&r last time
361085935165 on ebay
Thanks guys
If you cant find it......Grind it
Offline jonesltd
  • MK7 R
Re: Thoughts?
« Reply #1 on: 23 May 2016, 18:34 »
Anyone?
Offline itavaltalainen
Re: Thoughts?
« Reply #2 on: 23 May 2016, 18:38 »
Your ebay link is to alloy spacers....
Offline jonesltd
  • MK7 R
Re: Thoughts?
« Reply #3 on: 23 May 2016, 18:44 »
Yes they are well the number relates so I just wanted to know the answers to questions please
Offline Rhyso
Re: Thoughts?
« Reply #4 on: 23 May 2016, 19:26 »
VWR springs were a good choice on the MK6; helped with the handling without killing the ride quality
Offline jonesltd
  • MK7 R
Re: Thoughts?
« Reply #5 on: 23 May 2016, 19:27 »
So not coilovers like I had on the mk4?
Offline Rhyso
Re: Thoughts?
« Reply #6 on: 23 May 2016, 19:29 »
I wouldn't unless you plan on tracking
Did you ever change the ride heght on the MK4 once you had fitted the coilovers? If no, then I'd simply replace the springs
However, depending on mileage it might be worth changing the shocks. Depends how much you have / want to spend really  :undecided:
Offline jonesltd
  • MK7 R
Re: Thoughts?
« Reply #7 on: 23 May 2016, 20:09 »
Don't want to spend a great deal to be honest....200....
Also would like a little gap as possible or something nicer than my current oem ride height
Offline hepton
  • 2017 GTD
Re: Thoughts?
« Reply #8 on: 23 May 2016, 21:05 »
mines got lowered springs on with standard suspension ,the rides fine and the gap is tiny and handles well..
Offline jonesltd
  • MK7 R
Re: Thoughts?
« Reply #9 on: 23 May 2016, 21:07 »
Where did u get your springs from?
