Golf mk3
hardmonkeys
someone tell me whats wrong with my car!
Topic: someone tell me whats wrong with my car! (Read 2690 times)
adomakin
Just got here
24 October 2003, 07:52 »
can anyone help? my mk3 2litre16v is making some weird rapid "ch-ch-ch-ch-ch-ch-ch" noises and when its making the noise the brake pedal won't go down and i can feel a vibration (same as the noise) through the pedal. it seems like an abs problem but has anyone else had this or do they know what it might be? any help would be great as its well scary when you come to brake and all youve got is a rock hard pedal and a load of ch-ch-chs!
thanks,
Andy
adyh
Re:someone tell me whats wrong with my car!
24 October 2003, 09:42 »
Sounds like you have a sensor problem on your ABS mate. The only way to get it fixed is in the garage i expect .
Get them to read the fault codes from the ecu , and check the read out of the wheel sensors . (i know VAG-COM can do this)
adyh
24 October 2003, 12:23 »
Had a look , the system needs to bew able to read from module 3 . You need to do the test on the road or on a rolling road . I expect you will find that one of the sensors is showing 0 mph all the time .
golfvr6
Guest
24 October 2003, 13:58 »
I think something is wrong with the servo as well, maybe a leak? check the vacuum hose.
adomakin
Just got here
26 October 2003, 12:46 »
where can i find the sensors that you are talking about?
is there a sensor on each wheel?
im hoping that it may just be a sensor conection breaking down as the problem is only intermittent.
thanks,
Andy
golfvr6
Guest
26 October 2003, 18:48 »
Check the vacuum hose on the servo for security, also check the brake pedal positioner which is also mounted on the servo. I think if the pedal is rock hard then the servo is probably the problem, maybe a leak?
Si H
Reply #6 on:
31 October 2003, 14:27 »
Sounds like the abs sensors. I've had my '97 Mk 8v since new, and the only two things to ever go wrong with it were abs brake sensors. You problem sounds exactly like what I went through. Good luck.
golfvr6
Guest
Reply #7 on:
01 November 2003, 00:13 »
If the abs sensors are faulty then that would not make the pedal go rock hard, the only thing that does that is the servo not working properly.
Golf mk3
hardmonkeys
