The garage
Which Brakes should I get?
Topic: Which Brakes should I get? (Read 3488 times)
jaygolfgti
11 May 2016, 23:34 »
Hello,
So, my GTI MK5 Golf has some squeeking from the front right break. I've had it cleaned yet it still does it, advice is to get some new ones as must be un-even wear on the pad. Although the pads are still fine. Anyway, are all of these at the link an upgrade from what im guessing are the default gti pad and dics (i guess it has discs)?
http://www.demon-tweeks.co.uk/performance/disc-pad-brake-kits/car/volkswagen/golf-mk5-gti/2006/2-0-turbo
Which should I get? Budget ideally £50-150.
PS. I also want some that perform better that what I have and are unlikley to get squeaky!
Thanks!
The ANT
Here all the time
Re: Which Brakes should I get?
11 May 2016, 23:58 »
Squeaky brakes are normally because of the pads vibrating, normally copper grease is put on the back side of the pad between the pad and the caliper to absorb the vibration. My brakes still squeak though if they're hot.
Suffering from a severe and unforgiving case of GTItis
The garage
