Author Topic: Low oil pressure warning Golf GTI mark vi  (Read 7376 times)
Offline tcbirmingham
« on: 11 May 2016, 20:16 »
Hi guys, I'm new to this forum and apologise in advance if this subject has already been dealt with. I'm completely at a loss with my Gti and really hoping someone can help. I recently bought a mark vi Gti done 76,000 miles, from a private seller. All was well with the car including a full service history. 10 miles into the journey the low oil pressure light came on telling me to switch off the engine. I pulled up on to the side of the motorway and had the car recovered back to Birmingham. Needless to say the lad I bought the car from denied all knowledge and was pretty uninterested.
the first workshop it went into said they suspected the oil pump and changed the pump and pick up pipe as well as carry out an oil/filter change. drove home that evening and it seemed like the problem had gone. that was until I pulled up at some lights with the car at idle and the warning came back on. The warning however disappeared the second the car was revved and driven. As soon as it was stopped again with the engine at idle and the fault was back. It went back to the workshop who convinced me to change both oil pressure sensors. This was done and the car still has the same problem. its since been to two other 'specialists', one of whom claimed to adjust the timing on the oil pump (as it hadn't previously been done) and clean the sump. Again, the problem remains.
Its a strange one as the warning light only now comes on when the engine is warm and at idle. Really hoping one of you guys may be able to help. Its costing me over £10,000 and now I'm being told the engine needs replacing. Any help will be much appreciated!
Offline itavaltalainen
Re: Low oil pressure warning Golf GTI mark vi
« Reply #1 on: 11 May 2016, 22:20 »
Did they say why you need a new engine?
In short you have changed oil pressure sensors, assume wiring has been changed?
What oil pressure did they get when the alarm is on?
If pump has been changed and all is well and pressure is below what is expected then issue could be in engine itself, i.e. it is loosing oil pressure somewhere (bearings for example).
« Reply #2 on: 11 May 2016, 22:29 »
Thank you for the reply. The sensors were changed but not the wiring. It was taken to an auto electrician to check for a fault in the wiring. He however, after 10 minutes of looking at it, told me he had come across a few of these and all needed engine changes and that's what he suspected with this. He didn't give me any readings for oil pressure as apparently only Audi/VW have the tool to check the pressure on the TSI engine.
Offline mueneni12
« Reply #3 on: 14 May 2016, 17:57 »
Had same issue on mine and I suspect this is linked to the timing chain issue. I Had oil pump and intake manifold changed and in the end had to replace the whole engine.
Offline golfhappy
« Reply #4 on: 14 May 2016, 21:10 »
When your engine is at idle is there a bottom end rattle, even like a timing chain. Could be your big end bearings on the crank. Oil pressure is can be lost from here. It'll show up when the engine oil is hot as it will be less viscose. The shells might be worn. Unusual as it has a fsh.
Audi S1 gone, awaiting 1.5tsi r-line, pan roof, led lights front and rear, active dash, 18" jurva alloys and a dealer fitted Oettinger roof spoiler in tornado red.
