Author Topic: I need help mk3!!  (Read 5273 times)
Offline Liamc11
I need help mk3!!
« on: 11 May 2016, 00:23 »
Hi everyone hope someone can help me I own vw golf mk3 2.0 16v abf , it's been sitting for 11months , the battery died , I put a new battery on and it starts but only when I press the accelerator and it will not idle at all , as soon as I let the accelerator off it stalls , what can this be ?
Offline jimmydub
Re: I need help mk3!!
« Reply #1 on: 11 May 2016, 11:05 »
read through this:
http://www.golfgtiforum.co.uk/index.php?topic=2080.0
Will give you some ideas
Offline toMahawK3
« Reply #2 on: 12 May 2016, 10:34 »
Sounds like it's lacking in fuel, possibly the pump, pump relay, or injectors. Seems like it's not holding fuel pressure?
Offline Liamc11
« Reply #3 on: 12 May 2016, 11:23 »
Hi toMahawK3 that's what we thought cause it's been sitting for 11months maybe the injectors have got clogged , but also I found out that the fuel gauge isn't working don't no if this would affect it in any way , but I might just buy a pump relay and see what happens
Offline lemski
  • 16v
« Reply #4 on: 12 May 2016, 11:45 »
Unplug the maf see if it makes a difference. Am not that upto date with abf engines. They have a idle control switch on the throttle body, might all need fine tuning as its been sat. Throttle butterfly could be getting cought on corrosion in the throttl body not letting it tick over without revs
Offline Liamc11
« Reply #5 on: 12 May 2016, 12:53 »
Ok mate thanks I'll try that and see the outcome , :)
Offline Liamc11
« Reply #6 on: 13 May 2016, 08:55 »
Tried unplugging the Maf still nothing , I'm really confused , when I'm trying to start the engine it won't fire up on its own , but as soon as I tap the throttle it starts
Offline Liamc11
« Reply #7 on: 13 May 2016, 11:41 »
And also does anyone no if the mk3 gti 2.0 16v abf has a idle control screw , thanks
Offline Simeon
« Reply #8 on: 13 May 2016, 12:22 »
No, the idle is controlled by the ecu and the ISV. The ISV may be gunked up - it's located underneath the HT lead holder (3 small bolts to remove this) then check wiring to ISV and if all ok, remove ISV (one small bolt and pull out of the inlet manifold). Spray carb cleaner in it and give it a wipe out.
Has it got fresh fuel in it?
Offline Simeon
« Reply #9 on: 13 May 2016, 12:23 »
Also clean out the throttle body and check the vac lines, particularly the one from the inlet manifold to the ECU
