Author Topic: Brake line painting advice  (Read 9589 times)
Offline Jasikasisback
« on: 06 May 2016, 18:54 »
Recently had my car fail on "excessively corroded brake lines"... Hmmm if excessively corroded they should be leaking
Anyway...I have yet to own a car where the brake lines failed...and I lived in Canada where salt kills cars...they rot out and there are holes in the floor but brake lines never failed...
So now am taking a 20/year old golf for MOT and want to know if I can paint the lines on metallic paint...the lines look OK on this car but again the tester can just say...hey they are no good.
So is it OK just to clean and paint them with Hammerite?
Offline lemski
  • 16v
Re: Brake line painting advice
« Reply #1 on: 06 May 2016, 19:16 »
If we take a car to mot and theres a little corrosion we clean it up with a wire brush.
You can paint or underseal them in the UK but it can be advised because they cant see the condition of them.
If they clean up alright after a wire brush I cant see how they can fail them.
Also ive had a metal brakeline go after it had gone through an mot by the previous owner. It went down a hill.
« Reply #2 on: 06 May 2016, 20:00 »
So it can be an advisory if you paint the lines with rust deterring  paint like hammerite.
But not a fail...
I never had brake lines go on me in Canada on any car and.the rust was massive..I mean cars just rust away in less than a decade if you drive it during the winter...no amount of waxoil etc will save it.
Usually people have two cars, a summer one.and a winter one.
The way they salt the roads here the last few years (even.were.salting the roads a.few.weeks back in the M25, why I don't know as temperatures never.reached.zero) cars will rust out quicker..
When it is cold they put little salt...and.save it for April
I think the MOT overall is abused by most testers...it has made me.look over the whole car now before.the MOT..
I have checked everything on the golf, and I hope it doesn't fail...
Offline lemski
  • 16v
« Reply #3 on: 06 May 2016, 20:15 »
Its mot testers descretion, but ive only had them advised as they cant see if its corroded. Same with if the brake lines are under covers or reruted in through the car
« Reply #4 on: 07 May 2016, 10:03 »
My luck is that I get really strict testers...they could probably fail a brand new car....after all if something is excessively corroded...then it should leak...have a hole...if not then it is not excessive...this is totally subjective
Offline lemski
  • 16v
« Reply #5 on: 07 May 2016, 11:17 »
Well I can tell you that we have had a car go to one ppace and fail on something and took itto another and it failed on something totally different.
So what one test says is excessive another may think is only worth advising.
Have you got a picture of the brake lines your on about
« Reply #6 on: 07 May 2016, 12:52 »
Will take video later today
« Reply #7 on: 09 May 2016, 14:09 »
Failed MOT on faded number plate and insufficient nearsided wiper...will sort in next few days
Offline jimmydub
« Reply #8 on: 09 May 2016, 16:19 »
sounds like an overly critical tester to me, take it else where next time
« Reply #9 on: 09 May 2016, 18:21 »
He passed the car..the rear plate had mold in between the letters...how do I get the old plate off? How do I get the yellow things off on top of the screws...or do I have to destroy them??
The wiper blade needs replacing anyway...assume that ECP best place to get a replacement pair??carparts4less?
