Author Topic: Climate control temp incorrect  (Read 2552 times)
Offline remlapeel
« on: 02 May 2016, 17:14 »
Random one. I have noticed these last few days the temp on the climate control seems to be incorrect. For example - I drive under a wide bridge, probably 30 ft wide, naturally in an R you want to hear the noise....so the windows go down. Normally I can put the heaters on 24-25 and i get a good hit of warm air to balance out the cold from the windows. Today I was driving with the windows up, with the temp on 24-25 and the air was cold. - it was set to manual mode not auto, although the temp outside was warmer than normal 17-18 and I had to turn it up to 27 to get any heat at all.
Any ideas?
2015 MK7 Golf R 3 door, DSG, lapiz blue, 19" wheels, winter pack, keyless entry, dynaudio and high beam assist.
Offline Watts
Re: Climate control temp incorrect
« Reply #1 on: 02 May 2016, 17:26 »
I struggle getting mine to work in a logical fashion, the system in my Audi was much better, 21-22c with the aircon on permanently was warm and comfy with no misting up ever. The VW system has to be on 23-24c and often it's not that warm, I often feel cold in the car, never did in the Audi plus the VW can mist up easily and at times unexpectedly. I suppose it's a case of getting used to it and adjusting, nothing to get 'ahem' hot under the collar about...
Previously:
Offline Brenbo
« Reply #2 on: 02 May 2016, 17:28 »
What is your Air con set to... Strong or Light?  This can have an effect on the final overall temp of the climate control.
Offline Watts
« Reply #3 on: 03 May 2016, 14:32 »
Brenbo, mine is set to medium (I'm mostly a middle of the road, undecided kind of person). Would light be better then? Although with the forecast showing 23c and sun this weekend perhaps I'll need strong instead!
Previously:
Offline C2K
  • Northern Monkey
« Reply #4 on: 03 May 2016, 14:37 »
I must admit mine is mostly in auto, but i find it somewhat illogical that I have to intervene at times to demist the car (partly due to the fan speed being on like 1 because the car is satisfied with cabin temp).
My mate never touches a button in his A5 cabby and that works a treat all the while.
5 Door Night Blue GTD
Dynaudio, 19" Santiago Alloys, Adaptive Chassis, Leather Pack, Winter Pack, Reverse Camera.
Bianca White 306 Rallye (Supercharged + Caged) : Melting Silver F54 Mini Clubman Cooper S
Offline Watts
« Reply #5 on: 03 May 2016, 15:42 »
Exactly how my A4 was and my VW is. How can they work so differently, they must share components?
Previously:
