Author Topic: golf running rough on tick over revs going up n down  (Read 3312 times)
Offline yougy
its a vw golf mk4 gti 180 turbo, running rough on tick over and smelling of fuel. iv a laptop with delphi but no 100% wot im doing on it yet, scanned with vcds lite the free version and no fault codes, car has been remapped.
thats fooked it
Offline MoMartin
Re: golf running rough on tick over revs going up n down
« Reply #1 on: 30 April 2016, 20:41 »
The cheapest and easiest one to check is a dirty throttle body, that's sorted my problems in the past.
Offline yougy
« Reply #2 on: 01 May 2016, 10:57 »
looks like my post cat 02 sensor down no voltage
thats fooked it
Offline Dalo Harkin
« Reply #3 on: 02 May 2016, 10:19 »
Are you running a standard cat?
The post lambda won't adjust it that much to overfuel, check the throttle body and the MAF sensor first
Offline yougy
« Reply #4 on: 02 May 2016, 11:16 »
decat, new maf fitted and throttle body been changed, just picked up post 02 sensor when the stops I,ll fit it n see wots happens
thats fooked it
Offline Dalo Harkin
« Reply #5 on: 03 May 2016, 13:38 »
Your post o2 sensor is there mainly to protect the CAT from damage so changing it will do nothing if you have a decat
