Author Topic: Non Starting ABF since engine out, loom replacement  (Read 17529 times)
Offline hardmonkeys
  • Moderator
Hi all, Some of you may have been following my project thread, when I converted an
AGG auto into a ABF manual, I had it on the road last year for 3-4mths before I burnt the main loom out, so I bought a new loom, and started this week to replace it, So, all was going well, until today I went to start it.... It didn't!
It tries too, and will start with some persuasion with a little throttle, but is rough as!! And running Very rich, as soon as i let go of the throttle it cuts out immediately.. I'm going to try changing the leads and plugs tomorrow, see if that helps
The ISV is buzzing when the ignition is on, never heard this before, or never noticed it before, should it do this?
While the engine was out, I did remove the inlet manifold to clean up underneath...I put it all back together as previous, I replaced the gasket too, I probably shouldn't of touched it in hindsight lol
Any ideas?
'05 VW Golf Mk V GT TDI Laser Blue
'98 VW Golf Mk IV GTi Black
'97 VW Golf Mk III GTi
'58 VW Golf Mk V GT Sport TDI Steel Grey
'10 Audi A4 B8 SE Multitronic
'00 VW Golf Mk III.V Cabrio
'12 Audi A5 S Line Black Edition
'0 VW Golf V6 4motion
MK3.5 Cabrio 2.0 8v Automatic to 2.0 16v Manual Conversion Project
http://www.golfgtiforum.co.uk/index.php?topic=272728.
www.dorsetautorestore.co.uk
Offline lemski
  • 16v
Re: Non Starting ABF since engine out, loom replacement
« Reply #1 on: 24 April 2016, 21:25 »
Overfuelling wise.
Temp sender, maf or lambda id have said. Did you hear enhine running before you removed it?
Also if you scan it any codes
Offline hardmonkeys
  • Moderator
« Reply #2 on: 24 April 2016, 21:30 »
Yep, I ran it last year before the loom melted. And I used the donor car for a while before I stripped it for the engine and box.
It came up with a few codes, I didn't write them down like a fool, one of the was engine speed sensor, will check the inlet tomorrow. I replaced the gasket with new..admittedly aftermarket, tried VW but it's been discontinued.
Offline jimmydub
« Reply #3 on: 24 April 2016, 22:02 »
you may have damaged the engine speed sensor / crank sensor cable whilst doing the transplant. They go very brittle over the years.
I replaced mine a few weeks back, after similar starting and running issues like you've described.
Offline lemski
  • 16v
« Reply #4 on: 25 April 2016, 08:11 »
I was going to say that crank sensor wiring or sensor seems like the issue
Offline hardmonkeys
  • Moderator
« Reply #5 on: 25 April 2016, 09:14 »
Will have a ganders later 👍🏻
Offline hardmonkeys
  • Moderator
« Reply #6 on: 25 April 2016, 14:30 »
Just done a scan,
It's come up with
00513 - Engine Speed Sensor (G28): Implausible Signal
And
00740 - Cylinder 1 recognition sensor. (G145) No signal
Figured this is the Engine Speed Sensor
New sensor then.
« Last Edit: 25 April 2016, 14:34 by hardmonkeys »
Offline LR5V
« Reply #7 on: 25 April 2016, 17:39 »
ISV buzzing is a good thing.
as long as your engine idles when warm you dont need to worry about it
Offline hardmonkeys
  • Moderator
« Reply #8 on: 25 April 2016, 17:48 »
It's not starting mate, only with some throttle, When I hold the throttle down it keeps running but very rough, if I let go it cuts out. The wires to the crank position sensor are frayed, so I have a new sensor to fit tomorrow.
Offline LR5V
« Reply #9 on: 26 April 2016, 09:57 »
Yes - Crank sensor will stop it starting.
You were asking about the ISV in your first post.
If you can't feel it vibrate with ignition on you have a problem -as yours is buzzing like a jack rabbit you should be ok here
