Author Topic: Faut code  (Read 5092 times)
Offline martin200w
Faut code
« on: 22 April 2016, 11:27 »
Ive got the faut code 01044 on my code reader 281 dedicated to bag on the abs of my mk3 gti 1995 buid. Any ideas.
Thanks Martin.
Offline golfhappy
Re: Faut code
« Reply #1 on: 22 April 2016, 11:45 »
Audi S1 gone, awaiting 1.5tsi r-line, pan roof, led lights front and rear, active dash, 18" jurva alloys and a dealer fitted Oettinger roof spoiler in tornado red.
Offline martin200w
Re: Faut code
« Reply #2 on: 22 April 2016, 19:28 »
Will changing the module cure this fault code? Martin
Offline golfhappy
Re: Faut code
« Reply #3 on: 22 April 2016, 20:13 »
Don't really know, seems they did do software updates on it. You could get one of ebay and try it. Don't think it'll cost much.
Offline itavaltalainen
Re: Faut code
« Reply #4 on: 23 April 2016, 02:09 »
2 links below both say same thing http://wiki.ross-tech.com/wiki/index.php/01044 or in German and translate http://www.gerritspeek.nl/vag-com_dtc-01044.html
German? I'd say that's Dutch!
Incorrect coding seems strange on a 90s Golf..... I would have that checked out with a proper VW specific tool, not a handheld.
Get someone with VCDS to look at it.
Offline golfhappy
Re: Faut code
« Reply #5 on: 24 April 2016, 21:20 »
Yeh your right. Dutch.
Re: Faut code
« Reply #6 on: 24 April 2016, 22:49 »
Looks like the OP has solved the problem or not.....  :shocked:
Offline martin200w
Re: Faut code
« Reply #7 on: 12 May 2016, 17:57 »
I can't make a note of the original code because I don't what's been done to the car while I was in hospital.
All I know is it was OK before. How do I find what to code it to.?
Offline Jasikasisback
Re: Faut code
« Reply #8 on: 12 May 2016, 20:04 »
did you clear the code? Does it come back right away or only after you drive the car?
Remember that damp anywhere can cause the light to go on...on my B4 passat it was water in the boot near the central locking that caused it to go on...cleaned up the water and that was that....
They are old cars and sometimes the fault codes go off for reasons other than what they show...just remember that...
