Author Topic: *Sponsor Offer* Mk3 parts deals from www.oemandmore.co.uk  (Read 2929 times)
Offline boneybradley
  • Back in a Mk3...
We have bought a massive range of motor factor stock for the pre 2001 VW range and we are offering these are great prices and all with free UK delivery (we do post worldwide at cost too, ask us for a quote)
We may have available what you need, just ask as we have a list of 1000 items
Mk3 items......
Supersport Black Evolution Control+ coilover set (hardness and rebound adjustable) £265.00
H&R Lowering Springs VW Golf Mk3 VR6 > 97 £90.00
K&N 57i Intake Kit 1.4 1.6 with square filter £39.00
ABS sensor rear (earlier round plug) ATE £19.00
Alternator 90a 1.8 2.0 8v 16v by Valeo £92.00
Brake Caliper by ABS 280mm - £60.00 pair
Brake Caliper by ABS rear early £65 pair
Brake discs and pads 288mm by ABS £41.00 set
Brake power regulator (cars with drums) by TRW £59
Brake shoe and cylinder axle kit by Ferodo £39.00
Clutch Kit 2.8 VR6 LUK £59.00
Drive Shaft Left 2.0 8v GTI 2.0 16v & VR6 £55.00
Lambda sensor 2.0 8v 16v oval plug 94+ by Beru £42.00
Ignition leads set by Beru 1.4 ABD £21.00
Ignition leads set by NGK 1.4 ABD AEX £23.00
Ignition Leads Set 01/94 – 03/96 VR6 Bremi £20.00
Shock absorber oil filler Front 95+ by KYB £28.00 pair
Smoked fog lamps (complete units) by TYC £57.00 pair
Starter motor 2.0 8v 16v to 09/94 non air con by Valeo £59.00
Timing belt kit 1.4 AEX by INA £19.00
Timing Belt and water pump Kit 1.4 AEX by INA £24.00
Timing belt kit 1.8 ADZ ABS by Dayco £21.00
Timing Belt Kit 2.0 8V by Dayco £23.00
Timing Belt Kit 2.0 8V by INA £22.00
Timing Belt Kit 2.0 16v to abf 020 922 SKF £35.00
Track Control Arm w/o ball joints GTI/VR6 by Vaico £44.00 pair
Water pump 2.8 VR6 by Valeo £22.00
We also have a large range of alternators, starters, exhausts and radiators available (too many to list for the Mk3 range!) Ask us for a quote
We will continue to edit the post as items as sorted through or bought, to buy message us or email sales@oemandmore.co.uk
And for everything else for your VW
http://oemandmore.co.uk
« Last Edit: 13 May 2016, 20:25 by boneybradley »
  • Back in a Mk3...
First post updated....
