Author Topic: **Sponsor Offer** Weekly Mk4 deals from www.oemandmore.co.uk  (Read 2600 times)
Offline boneybradley
  • Back in a Mk3...
This weeks Mk4 offer's from www.oemandmore.co.uk
Hella Design rear lights black £89.00 pair
H&R coilover set R32 £700.00
Lowering spring set GTi/V5/1.9TDi -30mm £65.00
Lowering shock & spring kit (not diesel or tdi) -40mm £150.00
Lowering shock & spring kit Mk4 Cabrio -40mm £130.00
Shortened shock absorber set x4 £85.00
Brake discs and pads 288mm £44.00 axle set
Brake Disc Powerdisc by ATE 256mm vented rear £69.00 pair
Brake Disc Black diamond 232mm 6 groove rear £69.00 pair
Clutch kit & flywheel 1.8t AGU,ARZ,AUM by Sachs £288.00
Clutch Kit & slave cyl 1.9tdi 130 240mm by LUK £149.00
Lambda Sensor 1.8T Front by Beru £49.00
Oil Pan 1.9tdi with bore for oil-level sensor £44.00
Tie rod complete with ends £42.00 pair
Timing belt kit 1.8t to 00 or 00+ by INA £42.00
Timing belt kit 1.8t 00+ by Dayco £49.00
We will continue to edit the post as items as sold as these are limited stocks, to buy message us or email sales@oemandmore.co.uk
And for everything else for your Mk4 http://oemandmore.co.uk/vw-golf-mk4-1j-98-04-527-c.asp
Don't worry I drive a Mk4 myself so your in safe hands!!  :wink:
« Last Edit: 13 May 2016, 20:19 by boneybradley »
  • Back in a Mk3...
bump new offer's added in the updated first post, We have just bought 1000+ ex motor factor stock (mainly pre 2001 VW but plenty for the Mk4)
Ask us for a quote if what you need isn't listed or not on our website sales@oemandmore.co.uk
