Author Topic: 4 bar FPR  (Read 2231 times)
Offline Dalo Harkin
4 bar FPR
« on: 19 April 2016, 13:05 »
looking at my spec would a 4 bar FPR make any difference or should I just stick with the standard 3 bar, I'm replacing it anyway as its been on the car from new and while I am replacing vacuum tubing can do it then
I will also be adding a fuel pump at some point soon so will be upgrading that and the injectors to the S3 ones along with the 3" MAF.
« Last Edit: 19 April 2016, 13:10 by Dalo Harkin »
Offline lemski
  • 16v
Re: 4 bar FPR
« Reply #1 on: 19 April 2016, 14:13 »
4 bar gives an increase in fuel. Im changing mine for a 4. Little increase in power.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: 4 bar FPR
« Reply #2 on: 19 April 2016, 17:01 »
Extra fuel pressure won't make any difference. The only time you should change it is if your mapper asks for it
Offline RnP
  • Audi S4 gone, looking for b5 rs4
Re: 4 bar FPR
« Reply #3 on: 19 April 2016, 17:16 »
4bar FPR just kills fuel pumps.
Get yourself a DW pump or walbro and you'll be fine
