Author Topic: Mk3 gti abs pump/ecu  (Read 7302 times)
Offline Marb
« on: 16 April 2016, 21:29 »
Hi, does anyone out there know if the abs pump/ecu on a mk3 gti 16v is the same as 8v (for same production year) Pump looks the same, but I wonder if ecu is different?  My 16v is going to fail its next mot on abs not working and I know of an 8v part going cheap.  :smiley:
Offline madmanmart
Re: Mk3 gti abs pump/ecu
« Reply #1 on: 16 April 2016, 23:13 »
Pretty sure that 8v and 16v are different.
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
Offline LR5V
« Reply #2 on: 17 April 2016, 01:34 »
Yes they are different, 16v has a very basic traction control that they share with the VR6
in theory the 8v one should work -its a stand alone system, been retrofitted to Mk2's
btw The important part number is the one on the ECU black box underneath.
Offline snozan
« Reply #3 on: 17 April 2016, 07:52 »
The numbers on your existing ABS hydraulic pump must be EXACT with the one you change too. I had to change mine, got it off a SEAT.
The numbers can be found underneath.
Golf MK3 GTI 16v Colour Concept - Bumble bee Edition '96
Offline Marb
« Reply #4 on: 17 April 2016, 08:21 »
Ok, thanks everyone for that, almost wasted some money there!! I'll look out for a 16v one.
Offline snozan
« Reply #5 on: 17 April 2016, 17:14 »
Don't waste your money! All that counts are the numbers. As i said, i bought mine from a SEAT. Take a mirror and look what it says under yours. Just because you take it from a 16v dosen't mean it add up automatically.
Offline Marb
« Reply #6 on: 17 April 2016, 20:20 »
I hadn't thought about a mirror. I was thinking about buying a 16v abs unit in advance so I got the right one   and avoiding the car being off road for too long whilst I look for the part. Many thanks for your advice. smiley:
Offline SimonG
« Reply #7 on: 18 April 2016, 15:50 »
Not even all the 16V/VR6 have the same part number for the ECU.  Mine ends with 'A', a lot of others end with 'E'.
  Mk3 Anniversary GTI 16V, Mk2 GTI
Offline jimmydub
« Reply #8 on: 18 April 2016, 18:13 »
I can't see any numbers on the underside of mine, with or without a mirror!
Offline snozan
« Reply #9 on: 20 April 2016, 16:34 »
Underneath it looks like this (and the numbers you want to see, that have to be exactly the same with the one you're swapping)  :smiley:
