Author Topic: Additional Options/spec checker  (Read 2565 times)
Offline Lloydytd5
« on: 15 April 2016, 01:13 »
I'm interested in a gtd at an independent dealers but the dealers isn't sure on the additional options it has. From the pics I can determine it has the pro nav and winter pack, But unsure on things like dynamic chassis or headlight assist or sport and sound pack for example. Anyone know a website you can find out this information or would I be able to find out by ringing a Volkswagen dealer? thanks.
Offline gtiaps
Re: Additional Options/spec checker
« Reply #1 on: 15 April 2016, 05:59 »
My spec below this reply are all optional extras you would get the black and think grey seats as standard.
You can check out all the options on vw website and go onto build your car configuration..
2010 Candy White Scirocco 2.0 TDI
2016 Carbon Grey Gti 2.0 Fully Loaded
COLLECTED 29/4/2016 and well pleased with the GTI😆😆
Offline kalimon
  • My other car's a van
« Reply #2 on: 15 April 2016, 07:21 »
Is this a used or new car?
5 DR Mk 7 GTI PP
Offline Rhyso
« Reply #3 on: 15 April 2016, 07:47 »
Audi have a telephone you can ring and they will list the extras fitted
Not sure if VW have the same?  :undecided:
Offline Bungleaio
« Reply #4 on: 15 April 2016, 09:26 »
Inside the service book there is a list of codes on page one. These should tell you the list of things installed but to help you when looking at the car
Dynamic chassis - check by pressing the drive select mode (top left next to gear leaver) select individual. If it's got dynamic chassis then there will be an option for the suspension settings. I think it's the top one.
Headlight assist - Above the rear view mirror there will be a camera set into the mount for the mirror in the centre. Or if it's got lane assist there will be one on the screen in a triangular mount. Lane assist also gives little lights in the external mirror glass in the shape of a car, these will light up if a car is in your blind spot.
Sport and sound - Will have red callipers (this may be painted after market though)
Dynaudio - Sub in spare wheel plus dynaudio logo on tweeters in a panel
Park assist - Next to gear leaver middle right button will be present. if it's a blank it doesn't have it
Rear camera - Obvious when you put it in reverse
Climate screen - On the HVAC controls centre dial press the menu button on the lower half, there will be an icon on the bottom left of the main screen of some wires through the front screen, press this to heat it. There will also be a reddish/brown tint to the front screen. Car will also have advanced telephone connection and there will be USB socket in the centre arm rest.
Abarth 595 Turismo + Classic Mini + Triumph Street Triple RS
Did have 3door DBP GTI PP
Offline Lloydytd5
« Reply #5 on: 15 April 2016, 14:16 »
Thanks for the replies guys! helps a lot. And the car is used. The dealer doesn't even realise it's got the nav pro so could be onto a winner here.
Offline p3asa
« Reply #6 on: 16 April 2016, 01:12 »
If you put the codes from the service book into this website it will tell you what the car has.
http://igorweb.org/equidec.aspx
