Author Topic: 1.3L Carb - Very poor fuel economy  (Read 3363 times)
Offline LeeOxley
« on: 14 April 2016, 11:06 »
Looking for a list of reasons as to why my 1.3L might be getting only 17mpg. 150 miles to a fuel tank. Only mods are weber twin choke carb and a K&n Air filter. Doesn't misfire. Doesn't stink of fuel. Idles, runs and pulls perfectly in the day but carb ices over easily at night and has a flat spot at differing revs. No matter what time of day its always poor on fuel. I have tried to be more efficient with my driving but that only got me 167 miles to a tank so cannot call that conclusive really. Any help is appreciated.
Offline Waspy
Re: 1.3L Carb - Very poor fuel economy
« Reply #1 on: 14 April 2016, 12:38 »
I know jack about carb'd cars. But if it's driving fine, perhaps a leak?
Offline lemski
  • 16v
« Reply #2 on: 14 April 2016, 14:47 »
Chuck it on emissions. If its fine then theres gotta be a leak.
Maybe in a line under the car of the hose out the tank.
Was it OK before the webber?
Offline LeeOxley
« Reply #3 on: 14 April 2016, 15:16 »
Before the weber I hardly drove it as the choke had died. (typical Pierberg) and before that the Head gasket went, I bought it with the HG gone so it was rebuild by myself and my Grandad so I couldnt tell you. However, the past 3 years it has passed MOT with Zero advisories so theres nothing obvious.
Offline lemski
  • 16v
« Reply #4 on: 14 April 2016, 15:46 »
Whens the fuelling issue started. Made sure all connections are tight in fuel system.
Offline LeeOxley
« Reply #5 on: 14 April 2016, 15:49 »
I couldnt tell you when it started and all hoses  are tight
Offline lemski
  • 16v
« Reply #6 on: 14 April 2016, 16:01 »
Hmm. When I had a webber its wasnt amazing onfuel. I had twin choke 32/34
If the cars running fine. Emissions fine and you say there no leak, you could have it down jetted to allow better fuel economy.
Offline gazareth
« Reply #7 on: 16 April 2016, 14:50 »
first thing I would do is check all the brakes to make sure they are not binding. then I would re-check the camshaft timing and the ignition timing. if that all checks out fine then the next step would be get it on a dyno to set the carb up properly.
