Author Topic: Spigot rings  (Read 2514 times)
Offline Leggz11
Spigot rings
« on: 13 April 2016, 18:18 »
I have fitted after market alloys 19's DRC DRM and. spigot rings 57.1MM- 73.1MM had the tracking done the wheels balanced and still get vibrations at 70MPH plus wondering as they are plastic and not metal is this maybe why ? Any help appreciated
Re: Spigot rings
« Reply #1 on: 17 April 2016, 21:52 »
Hi Leggz,
It's a possibility but unlikely so long as the bolts are done up tight and they don't protrude from the back of the wheel stopping the hub/disc and wheel mating together tightly.
Try moving the wheels around to different axles/sides and seeing if it's any different.
Also try putting the wheels and tyres on a wheel balancing machine and lightly hold a bit of chalk against the tyres back and front, and against the alloys to see if there are any buckles or tyres misshaped.
I had an old GTI years ago that drove me nuts for ages, tried all sorts, it ended up being a tyre gone out of shape. Impossible to see with the car on the ground.
Offline Mattyj
Re: Spigot rings
« Reply #2 on: 30 April 2016, 12:33 »
Chances of it being spigot rings are very slim,whell bolts loose of balancing thats the nirm un,ess you have serious problem somewhere
