Author Topic: Rns 510 upgrade question  (Read 3271 times)
Offline patters1978
« on: 10 April 2016, 09:42 »
Hi everyone
Firstly gotta say I'm running a mk5 Jetta but my question should be relevant.
Anyway have done my rns 510 upgrade with the upgraded canbus and since have lost my rear defroster? Press the button and straight away light goes out on button! It worked 30 mins before the upgrade
Does anyone know if this is a option that can be enabled/disabled from the canbus? Via vagcom?
If it is a option via vag anyone around Tamworth area that can help? As I don't have vag :(
Offline golfhappy
Re: Rns 510 upgrade question
« Reply #1 on: 10 April 2016, 14:02 »
Had a similar problem when a new CECM was installed although the long coding was copied from the old one the boxes for the heated seats and the air con were not ticked, they still worked. The rear screen demister which was ticked didn't
When you pressed the switch it lit and the info came up on the RNS510 then went off! sound similar problem. Just ticked the heated seats,air con and low and behold the rear screen was happy!
Audi S1 gone, awaiting 1.5tsi r-line, pan roof, led lights front and rear, active dash, 18" jurva alloys and a dealer fitted Oettinger roof spoiler in tornado red.
