Author Topic: Can Heated Seats Be Retrofitted ?  (Read 8992 times)
Offline gENERIX
« on: 08 April 2016, 12:28 »
Hi folks,
I recently purchased a set of leather heated seats from out of a MK6 R. Can anyone tell me whether I the heated seats can be retrofitted to a Non GTI that never had them originally fitted? If so, what parts will be required?
Your help would be much appreciated folks.
Thanks
Offline jv
  • Administrator
Re: Can Heated Seats Be Retrofitted ?
« Reply #1 on: 08 April 2016, 12:36 »
Essentially it's just some wiring and switches. Auto electrician would be able to do it no problem.
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
Offline golfhappy
« Reply #2 on: 08 April 2016, 13:27 »
There is a byte in CCEM, cant remember which one. Basically you'd have get VCDS and scan module 9 to see if the module supported heated seat function. Then as JV says some wiring etc. Hope that helps.
Audi S1 gone, awaiting 1.5tsi r-line, pan roof, led lights front and rear, active dash, 18" jurva alloys and a dealer fitted Oettinger roof spoiler in tornado red.
Offline gENERIX
« Reply #3 on: 08 April 2016, 13:58 »
So my best bet is buying the switches from a Volkswagen Dealership and contact an Auto Electrician and explain what I'm looking to do?
Offline jv
  • Administrator
« Reply #4 on: 08 April 2016, 14:59 »
Sorry, slightly more that a bit of wiring as happy says :)
You could do with a friendly VW specialist, they could sort the lot. Where are you based?
Buy site stuff!
Offline golfhappy
« Reply #5 on: 08 April 2016, 15:21 »
Probably your shopping list would be right/left heated seat switches, loom, and certainly you'd have to check that CCEM to see if the software supported heated seats. If not it may be a dealer upgrade of here said software or a new module. New module £250 you can sometimes get one from ebay.
Just checked if you get someone to scan your car its byte 22 in module 9. I would think if it's going to support heated seats it will be there.
http://www.ebay.co.uk/itm/VW-GOLF-MK6-CLIMATE-CONTROL-PANEL-5K0-907-044-AK-GOLF-CLIMATE-UNIT-5K0907044AK-/272174790799?hash=item3f5ee1b88f:g:O-oAAOSwYlJW6r46
« Last Edit: 08 April 2016, 15:48 by golfhappy »
Offline golfhappy
« Reply #6 on: 08 April 2016, 20:57 »
See post #9 in this thread not much help but this boy did retrofit into his MK6 http://forums.ross-tech.com/showthread.php?1995-Heated-Seat-Fault-Code-Help-Please
Offline AntGTD
« Reply #7 on: 08 April 2016, 23:01 »
Eddie is the go-to guy when it comes to retrofits.
2016 Mk7 Golf GTD 180(ish) Reflex Silver with loads of stuff
