Author Topic: front mount on a stage 1  (Read 3483 times)
Offline viperjsy
« on: 08 April 2016, 02:33 »
hi should I fit a front mount on a stage 1 roughly 190bhp thank you
Offline lemski
  • 16v
Re: front mount on a stage 1
« Reply #1 on: 08 April 2016, 08:40 »
Dont have to. But itll help. Plus if you plan to go for in the furure the fm is already there
Offline Dalo Harkin
« Reply #2 on: 08 April 2016, 08:57 »
You will notice a LOT of lag on a stage 1, if going to a stage 2 then you want 2.5 inch piping (going bigger than a K03s then you might need 3 inch)
« Last Edit: 08 April 2016, 13:24 by Dalo Harkin »
Offline Scott D
« Reply #3 on: 08 April 2016, 17:02 »
I wouldn't bother for stage 1 the standard side mount is more than capable
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline viperjsy
« Reply #4 on: 08 April 2016, 17:07 »
thank you
Offline Dalo Harkin
« Reply #5 on: 11 April 2016, 08:43 »
If you plan on keeping the standard SMIC, you may want to do the wheel arch liner mod to it
Offline viperjsy
« Reply #6 on: 14 April 2016, 03:02 »
already done
Offline yougy
« Reply #7 on: 01 May 2016, 11:02 »
wots the standard mot to wheel arch
thats fooked it
Offline gti gurl
« Reply #8 on: 01 May 2016, 21:43 »
I was told when you map them it makes the turbo work it's tits off so having a front mount will keep it cooler but you could probably get away with standard one for stage 1.
Im no cactus expert but i know a prick when i see one !!!
