Author Topic: Lock barrel repair.  (Read 3543 times)
Offline Jasikasisback
Lock barrel repair.
« on: 05 April 2016, 20:22 »
The lock barrel on my passenger side has fallen apart. Is it possible to take a working handle and lock out and just switch the tumblers??Anyone have a guide/link  to doing this?
Offline itavaltalainen
Re: Lock barrel repair.
« Reply #1 on: 05 April 2016, 21:19 »
What's fallen off?
Handle is not an integral part of the lock, you should be able to keep the old one.
http://partscatalog.info/volkswagen/en/img/vw/121/121837000.png
« Reply #2 on: 05 April 2016, 22:53 »
Part 21 has lost the hook...so I want to take the locking mechanism from one car and swap the innards of the lock mechanism into the other while retaining the lock barrel of the primary car so can use the same key
« Last Edit: 06 April 2016, 13:54 by Jasikasisback »
« Reply #3 on: 05 April 2016, 22:55 »
Looks like parts 25,24 and 23 also fell off
« Reply #4 on: 06 April 2016, 13:58 »
Can this be done by removing the lock components from the inside of the door? I don't have a torx or spline bit for the screw that holds the door handle in place. I've got the door cards off already..if not what is the size of the torx/spline screw and I will try to get one...;)
« Reply #5 on: 06 April 2016, 18:45 »
Nope not really, you need to undo the torx screw. Can look up what size torx it is, driver is dead cheap.
I got a spare part 21 at home, can send that to you.
« Reply #6 on: 27 April 2016, 21:08 »
All sorted...all faults on car now sorted...will get car ready for MOT
