Author Topic: Soundaktor disconnection  (Read 104001 times)
Offline I wanted a GTi
Re: Soundaktor disconnection
« Reply #40 on: 09 May 2017, 07:53 »
Things I've done
Full brake lights
Soundcraper set to 0%
XDS set to strong
Fan shows speed when in auto
Mode button set to not change colour
DRL's set to 100% with lights on
DRL's set to Scandinavian, rear lights on with DRL
Comfort indicators set to 4 flashes
Set the discover screen to be a little less fussy
Front fogs on with main beam
Coming/leaving home set to auto when drivers door open
Coming/leaving home lights set to DRL's and fogs
Interior lights set to not light when the boot is open
There might be other stuff I've done but that's all I can think of at the moment. I should be around your way next week but if not I can send you both the OBDeleven and my Nexus 7 and you send them back when you're finished with it.
XDS to strong, do you feel that?. Couldn´t that cause problems?.. :)
I'll change it to soft and go for a spin(no pun intended)  see what the difference is. What problems could it cause having it set to hard? I had it set to hard for years on my CC's with no problems.
Offline andy28
« Reply #41 on: 09 May 2017, 21:51 »
Has anyone tried OBDeleven on a 7.5 yet?
GTI Clubsport Edition 40
#301 and then #190
Offline hog_hedge
« Reply #42 on: 09 May 2017, 21:54 »
I have used VCDS and it worked just fine so I should imagine OBDeleven should work the same too.
Offline andy28
« Reply #43 on: 09 May 2017, 22:34 »
Thanks Hog_Hedge, I'll give it a try. Andy
#301 and then #190
« Reply #44 on: 10 May 2017, 09:07 »
Have you got an OBDeleven or are you going to buy one? Might be worth trying to get someone close to you to try it with theirs first. Where are you?
Offline andy28
« Reply #45 on: 10 May 2017, 13:30 »
I have ordered one but then read on a forum that not all of the one click adaptations would work with the facelift model! Their support guys have just come back to me today and it looks like the only one missing that I'm bothered about is the Scandinavian Lights and it might be possible with long coding. I will try it when it arrives and if I'm not happy, I'll just return it within the 30 days - although I think it has to go back to Lithuania. I'm based in South Manchester btw so happy to help others if I can get it working. Andy
#301 and then #190
« Reply #46 on: 10 May 2017, 14:33 »
I'm going up your way at some point to meet kalimon at some point and I could have meet you as well.
Is there no way we can sort something out on the forum so that people who have it can help others who don't. I know it is only £50 but if all your going to do is a few little tweaks it is expensive espically so if you don't use an android device.
I'm in solihull area but I don't mind a little travel to help out another forum member.
Offline andy28
« Reply #47 on: 10 May 2017, 21:42 »
No worries, it means I can take my time and have a play with the different options but thank you very much for the v kind offer. I've said it before but I love how helpful and friendly this forum is!
#301 and then #190
« Reply #48 on: 11 May 2017, 10:06 »
No problems, I take it that you bought the pro version? I would recommend doing as much research as possible before diving in. Also before you change anything make sure you back-up the original setting.
Check this site out as well if you haven't already done so http://obdeleven.proboards.com/board/81/mk7
« Last Edit: 11 May 2017, 10:16 by I wanted a GTi »
Offline andy28
« Reply #49 on: 23 May 2017, 21:20 »
I've been having some great fun with my obdeleven pro, what a fantastic bit of kit... I turned off the soundactor (but then missed it so turned it back up to 30% haha), increased lane change indicators to 4 and turned on Scandinavian DRLs. On this last change, is it right that the light dial always shows that the lights are on (i.e. a green light even on 'O') and the interior lights (footwell, led door strips etc) are always on too? Cheers, Andy
#301 and then #190
