Author Topic: Soundaktor disconnection  (Read 103967 times)
Offline hobbes22
Re: Soundaktor disconnection
« Reply #20 on: 22 April 2017, 09:21 »
I'm currently waiting for my OBDeleven to arrive. Is it easy enough to turn off the SoundAktor?
Sold - Octavia 2.0 PD Tdi. Shark remap. EGR Delete. Decat. H&R Shocks. Hybrid Turbo.
Sold - 2016 GTI PP, Manual. Pure White. Keyless.
Current - GTI Performance, DSG, Isaac Blue, Brescia 19”.
Offline I wanted a GTi
« Reply #21 on: 22 April 2017, 09:27 »
Simple, I'll get you some screen shots later if you want.
This is a very informative site http://obdeleven.proboards.com/board/81/mk7
Offline Watts
« Reply #22 on: 22 April 2017, 10:30 »
Still happy with mine connected, but now I have the pedal box fitted, I don't use sport mode anymore so the soundaktor is quieter. Mind you, over the last few months I've noticed the exhaust note has changed like it has a bit more of a rasp to it. Has anyone else noticed that as the miles build up? Mine's on about 15.5k now.
Previously:
Offline hobbes22
« Reply #23 on: 22 April 2017, 18:27 »
Thanks!  :smiley:
« Reply #24 on: 22 April 2017, 19:56 »
Here you go, just follow the red dots.
Scroll down to bottom and
Tap
Tap
Tap
Put in the % you want, 0%(off) to 100% and then tap the green check
I forgot to get the last part which is yet another green check and when you tap it it should briefly say adaptioned changed.
Offline Mk1Macca
« Reply #25 on: 23 April 2017, 09:37 »
Is it active in normal mode on a GTi 7.5? The dealer said no, it only turned on in sport mode, but I'm not so sure.
« Reply #26 on: 23 April 2017, 10:51 »
If it is like the Mk7 then it is on all the time but at different levels.
Sport-full
Normal-less
Eco-less still
Offline hobbes22
« Reply #27 on: 23 April 2017, 18:20 »
Thanks for the guide.  :cool:  Hopefully OBD11 will turn up this week.
Offline Gulfstream11
« Reply #28 on: 24 April 2017, 08:08 »
The first thing I did when OBD11 arrived was to switch that off. I can now hear the exhaust and the farts.
Previous rides..MKIV 1.8T   MKIV PD150  MK5 GTI MK5 edition30 now MK7 GTI PP
Offline tictap
« Reply #29 on: 24 April 2017, 10:17 »
Is there a particular model of OBD11? had a quick google search and they start from around £27, are these any good?
MK7 GTI, Keyless, Pano Roof, Discover Pro, Dynaudio, Leather Interior, Winter Pack, Performance Pack
