Author Topic: cylinder numbers  (Read 3672 times)
Offline lemski
  • 16v
Re: cylinder numbers
« Reply #10 on: 04 April 2016, 22:34 »
Cant see it. Unless the earth isnt on the rocker or youve managed somehow to trap a wire.
Take the breather of. Real longshot but it eliminates that.
Maybe coilpack loom plug is loose and underload its connecting, Disconnecting.
Offline gamestaffords
« Reply #11 on: 04 April 2016, 22:42 »
did think about the plug.. is there anyway of testing it with a multi meter? do you know much about that that pcv valve cus i brought a cheap set of breather hoses and it came with a pcv valve so i changed them all but the valve was faulty,, was getting random misfires so put original valve back in now just cylinder 4 could that of caused any more hassle??? sorry for all the long posts but its the family car F****D without it
Offline lemski
  • 16v
« Reply #12 on: 04 April 2016, 23:01 »
If you take the pvc valve out then all the breathing system will vent to air.
On a s3 I did I replaced all the breathing sytem with silicone piping and kept the pvc valve in place. Nit that it helps you alot.
The metal clips should be down firm.
(with out looking at my 20vt engine thats at the workshop) im sure that the loom runs.close to the rocker into the main loom so you may have trapped the wire.
Vag com will test if there getting the correct current throufh the plugs. When thw cars not running am sure theres no current.
« Reply #13 on: 06 April 2016, 07:52 »
still stuck on this fault lads,,,been reading about a solenoid by the CCT could this maybe the problem??
Offline Dalo Harkin
« Reply #14 on: 06 April 2016, 08:54 »
Have you checked the spring inside the coil pack can/is make contact with the spark plug, take it off and look inside (sounds daft but a mate of mine was messing with his loads and part of the spring broke off and it wasn't making a connection)
if you have checked the coil packs and the misfire doesn't move then you can rule them out (except for the above)
plugs checked and same thing.
The only thing I could thing next would be the wiring harness to the number 4 coil pack, its an easy fix, just get a plug online (or on here if someone breaking) and solder the new one on.
A pic might still be useful in case there is something we can see you aren't aware of
Offline lemski
  • 16v
« Reply #15 on: 06 April 2016, 11:49 »
Im with Dan. Ive got a spare coilpack loom I think. Ill have a look if you want.
Again a picture would help us see something that you may have overlooked
