Author Topic: Problem after fitting 008p  (Read 3026 times)
Offline RnP
  • Audi S4 gone, looking for b5 rs4
« on: 02 April 2016, 06:41 »
In February I had a new oem diverter valve fitted and all was well.i bought a brand new forge 008p and fitted it correctly with the yellow spring as I'm running a stage 2.
After having it fitted I noticed the car would judder/misfire when on part throttle. It only happens when I'm driving conservatively and easing up through the gears. If I floor it and go through the gears it's fine.
I thought changing the spring in the valve to green would cure it but no.
I know it's a weird problem anyone able to shed any light.
Offline Nino
  • Insta - F6UGA
Re: Problem after fitting 008p
« Reply #1 on: 02 April 2016, 09:01 »
Green spring is standard map, yellow is stage one map i think you need ether a blue or red spring.
Have you done a n249 bypass? If not I'd recommend it.
Current - MK6 GTi Edition 35
Offline RnP
« Reply #2 on: 02 April 2016, 10:17 »
Not done the n249 bypass yet. Was on the cards for later on in the year.
I put the yellow spring in the valve originally and replaced it with the green spring. Problem still persists.
I will try the blue spring later today if that doesn't fix it I may swap back to the oem valve as I had no issues with that on.
Surely couldn't be a faulty forge 008p?
« Last Edit: 02 April 2016, 10:20 by RnP »
Offline Dalo Harkin
« Reply #3 on: 03 April 2016, 09:27 »
Blue spring is too much, what boost you seeing? Mines 1.7 bar on my stage 2 and I use a yellow spring. I'm right on the crossover point so could get away with a blue spring but it's a little too aggressive I think.
Are you sure you haven't disturbed anything while fitting?
Offline RnP
« Reply #4 on: 04 April 2016, 22:07 »
Today I put the stock oem diverter valve back on and the problems still persists.
I'm starting to think I've definitely disturbed something along the way. Question is what would cause this sort of problem. I had a pretty good look at the pipes in that vacinity but couldn't see anything a miss. Would a smoke test show what's causing this?
Offline Nino
  • Insta - F6UGA
« Reply #5 on: 05 April 2016, 16:56 »
could have a damaged n75, but my money is on a boost leak, check all the pipes in and around it, id also do a n249 bypass while your there.
Offline Dalo Harkin
« Reply #6 on: 05 April 2016, 17:18 »
Check and double check, take each piece of boost piping off (the small ones that are about 3mm internal diameter would be my bet) so the ones running to the top of the DV and around the inlet manifold to the boost gauge if you have one, FPR etc. cover one end with your finger and blow into each piece, the one you don't get a red face on is knackered  :smiley:
« Last Edit: 05 April 2016, 17:20 by Dalo Harkin »
Offline RnP
« Reply #7 on: 05 April 2016, 17:28 »
Cheers lads for your input I appreciate it all. I don't have a day off until the 20th so will report back.
Offline RnP
« Reply #8 on: 06 April 2016, 20:21 »
Remind me to buy you a beer :laugh:
Offline Dalo Harkin
« Reply #9 on: 07 April 2016, 12:26 »
you owe me a beer  :grin:
