Author Topic: MK5 GTI 2.0 TFSI Misfire Advise..  (Read 3586 times)
Offline Jayy
« on: 28 March 2016, 18:12 »
Hi Guys,
Some advise please..
VCDS brings up;
000768 Random/Multiple Misfire Detected P0300 001
000771 Cylinder 3 P0303 001 Misfire Detected
008801 Boost Pressure Control Valve N249 P2261 Mechanical Malfunction
Basically got a low down misfire, sounds quite rough, however at higher speed, and higher gears it seems to go away, and also in the higher rev range.
HPFP has been changed, along with the sensor, and the cam follower, and coil packs have been tested and are fine, any advise on where to go next?
I can't find the log, or block to check the injectors on VCDS, anyone help me on where that is?
Offline Rhyso
Re: MK5 GTI 2.0 TFSI Misfire Advise..
« Reply #1 on: 28 March 2016, 20:51 »
Changed the spark plugs??
Offline Jayy
« Reply #2 on: 28 March 2016, 23:08 »
yes mate, plugs, coil, hpfp, the sensor that goes on it, and cam follower all changed
