Author Topic: R32 - fan constantly spinning  (Read 3493 times)
Offline NotMyName
« on: 25 March 2016, 22:44 »
The fan is always spinning on my brothers R32. He had some coolant sensor renewed which i think he said calmed it down for a bit but it's back to as it was now.
I came to drive it tonight, started it up, moved it a bit, turned it off & the fan was instantly spinning away for ages.
Drove it to my house, turned engine off, fan spinning again for ages.
Quote
Chassis Type: 1K (7N0)
Scan: 01 03 08 09 15 16 17 19 22 25 37 42 44 46 52 55 56 62 72
Mileage: 153340km-95281miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine        Labels: 022-906-032-BDB.lbl
   Part No SW: 022 906 032 CD    HW:
   Component: MOTRONIC ME7.1.1    7802
   Revision: --H01---    Serial number: VWZ7Z0E2912108
   Coding: 0000172
   Shop #: WSC 01279 785 00200
   VCID: 4FAD1627DE677146B8-801A
3 Faults Found:
012313 - Valve for Exhaust Flap 1 (N321)
               P3019 - 004 - Open Circuit - Intermittent
000278 - Engine Coolant Temp. Sensor (G62)
               P0116 - 008 - Implausible Signal - MIL ON
004416 - Oxygen (Lambda) Sensor; B2 S2
               P1140 - 008 - Internal Resistance too High - Intermittent
Readiness: 0000 1001
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-A.lbl
   Part No SW: 1K0 907 379 AB    HW: 1K0 907 379 AB
   Component: ESP 4MOTION MK60    0102
   Revision: 00H13001
   Coding: 0004744
   VCID: 72EBBFD36D157CAE77-8026
No fault code found.
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1K0 907 044 BE
   Component: ClimatronicPQ35 090 0808
   Shop #: WSC 00000 000 00000
   VCID: 6BD5A2B74A3FAD66B4-803E
1 Fault Found:
00819 - High Pressure Sensor (G65)
            009 - Open or Short to Ground
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000002275548
   Coding: E68F8F2700041800001400001400000000087B075C
   Shop #: WSC 01392 785 00200
   VCID: 2B5562B78ABF6D66F4-807E
   Subsystem 1 - Part No: 1K2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  013  0402
   Coding: 00065493
   Shop #: WSC 01392
   Subsystem 2 - Part No: 1K0 955 559 T  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 011  1110
   Coding: 00207646
   Shop #: WSC 01392
4 Faults Found:
02092 - Enabling Heated Seat
             Freeze Frame:
                    Fault Status: 01101001
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 125
                    Mileage: 148840 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 13.90 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
00924 - Relay for Headlamp Cleaning System (J39)
            009 - Open or Short to Ground - Intermittent
             Freeze Frame:
                    Fault Status: 00101001
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 140
                    Mileage: 152001 km
                    Time Indication: 0
             Freeze Frame:
                        OFF
                    Voltage: 12.00 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
01499 - Bulb for High-Beams; Right (M32)
            010 - Open or Short to Plus - Intermittent
             Freeze Frame:
                    Fault Status: 00101010
                    Fault Priority: 3
                    Fault Frequency: 3
                    Reset counter: 164
                    Mileage: 151405 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 13.35 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
00979 - Lamp for Low Beam; Right (M31)
             Freeze Frame:
                    Fault Status: 00111010
                    Fault Priority: 1
                    Fault Frequency: 32
                    Reset counter: 160
                    Mileage: 149839 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 13.75 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 P    HW: 1K0 909 605 P
   Component: 2F AIRBAG VW8R  032 7900
   Revision: 03032000    Serial number: 0038FD03SX3K
   Coding: 0012870
   Shop #: WSC 01269 785 00200
   VCID: 397948FF70E3CFF676-806C
   Subsystem 1 - Serial number: 6332MSME0E096737H
   Subsystem 2 - Serial number: 6342MSME0D6F3508M
   Subsystem 3 - Serial number: 6352QSME07164D65J
   Subsystem 4 - Serial number: 6362QSME07024B09B
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 AF    HW: 1K0 953 549 AF
   Component: Lenksäulenmodul 634 0070
   Coding: 0000012
   VCID: 76E383C3017D608E5B-8022
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1K6 920 972 F
   Component: KOMBIINSTRUMENT VDD 4316
   Coding: 0005403
   Shop #: WSC 00001 001 00001
   VCID: 356144CF5CFB2B9692-8060
Address 19: CAN Gateway (J533)       Labels: 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 R    HW: 7N0 907 530 H
   Component: J533  Gateway H42 1632
   Revision:   H42       Serial number: 100812F2000060
   Coding: 350003
   Shop #: WSC 12345 123 12345
   VCID: 3F8D26E7AEC7E1C648-806A
Address 22: AWD        Labels: 1K0-907-554.lbl
   Part No: 1K0 907 554 C
   Component: HALDEX 4Motion      0108
   Coding: 0000001
   VCID: 2D516CAFB4AB6356EA-8078
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VDD 4316
   Shop #: WSC 00069 210 90065
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 C    HW: 1T0 035 680 C
   Component: RNS-MID       H41 2720
   Revision: AB001001    Serial number: VWZ6Z7K9223163
   Coding: 040004000400000200
   Shop #: WSC 01357 011 00200
   VCID: 2E536BA379AD184ED3-807A
2 Faults Found:
01044 - Control Module Incorrectly Coded
            000 -  -  - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 5
                    Fault Frequency: 254
                    Reset counter: 165
                    Mileage: 148840 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 06:20:41
00862 - Antenna for GPS Navigation (R50/R52)
            007 - Short to Ground
             Freeze Frame:
                    Fault Status: 01100111
                    Fault Priority: 5
                    Reset counter: 125
                    Mileage: 148840 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 05:55:06
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN2.lbl
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2388
   Coding: 0000692
   VCID: 366343C341FD208E9B-8062
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 K
   Component: EPS_ZFLS Kl.5   D06 1701
   VCID: 346779CB5781329EA5-8060
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 AR    HW: 1K0 959 433 AR
   Component: 01 KSG PQ35 G2  010 0101
   Revision: 00010000    Serial number: 00000000000000
   Coding: 819002085103087F2D04840570085FC690A440
   VCID: 000FE51B53B95E3E71-8054
   Subsystem 1 - Component:   Sounder No Answer
   Subsystem 2 - Part No: 1K0 907 719 C
   Component: Neigungssensor  005 0003
   Subsystem 3 - Part No: 1K0 951 177 A
   Component: Innenraumueberw.005 0202
2 Faults Found:
01134 - Alarm Horn (H12)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 100
                    Mileage: 0 km
                    Time Indication: 0
01135 - Interior Monitoring Sensors
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 4
                    Fault Frequency: 196
                    Reset counter: 165
                    Mileage: 0 km
                    Time Indication: 0
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN2.lbl
   Part No: 1K0 959 702 K
   Coding: 0000692
   VCID: 377D4EC746F7D98680-8062
1 Fault Found:
00110 - Right Mirror Turn Signal Lamp (L132)
            012 - Electrical Fault in Circuit - Intermittent
Address 55: Headlight Range        Labels: 1T0-907-357.lbl
   Part No: 1T0 907 357
   Component: Dynamische LWR      0003
   Coding: 0000004
   VCID: 74E7B9CB1701729E65-8020
1 Fault Found:
01533 - Terminal 56 (High Beams)
            011 - Open Circuit - Intermittent
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 5
                    Reset counter: 165
                    Mileage: 148840 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 06:20:41
             Freeze Frame:
                    Fault Priority: 5
                    Reset counter: 125
                    Mileage: 148840 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 05:55:06
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN2.lbl
   Part No: 1K0 959 703 F
   Component: Tuer-SG         021 2429
   Coding: 0000144
   VCID: 33657AD7528F35A6BC-8066
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN2.lbl
   Part No: 1K0 959 704 F
   Coding: 0000144
End-------------------------(Elapsed Time: 01:54)--------------------------
