Author Topic: Boot lock problem  (Read 3598 times)
Offline rbean
Boot lock problem
« on: 23 March 2016, 21:01 »
hi everyone new to this forum so apologies if I'm in the wrong place, please point me in the right direction if I am.
I recently bought a mk4 golf v6 4motion as a project (it had been sat outside for about 3 years :( )
I have got it all running and driving but one thing I can not fix is the boot lock and its driving me nuts...,.
so ....
the boot is open, but it won't lock with the key or central locking, I've removed all interior panels to get to the lock and can see that the central locking is moving but the latch its self is not locking ( if I close the boot I can open it without using the handle)
So I've replaced the latch but still have the same problem....,
If anyone could help with this matter it would be greatly appreciated   :)
Offline rbean
Re: Boot lock problem
« Reply #1 on: 23 March 2016, 21:49 »
any help would be appreciated no matter how small :)
Offline itavaltalainen
« Reply #2 on: 23 March 2016, 21:53 »
I'd replace the lock completely?
Offline rbean
« Reply #3 on: 23 March 2016, 22:04 »
I was thinking that but I wanted to make sure I rule everything out before forking out for a new lock to find out it still doesn't work :/ e.g something electrical
Offline lemski
  • 16v
« Reply #4 on: 23 March 2016, 22:13 »
Id say lock, if you think its electrical unplug the connector for.central locking, thatll rule that out then
Offline rbean
« Reply #5 on: 23 March 2016, 22:24 »
will give it a go in the morning, it just seems strange that when you close the boot it won't even latch properly , for some reason the latch isn't catching and its all in line ( I've been sat inside the boot for hours opening and closing the boot trying to work out what it is.
obviously the easy fix would be a complete new lock just trying to save some pennies :)
« Last Edit: 23 March 2016, 22:35 by rbean »
Offline lemski
  • 16v
« Reply #6 on: 23 March 2016, 22:42 »
I hear ya, i had to diavnose a central locking fault on the passat, turns out a previous owner had replaced the mech but never.plugged.it back in.
« Reply #7 on: 23 March 2016, 22:49 »
IF it does not lock with key than it won't be electrical. Usual electrical issues would only stop it from locking with central locking.
Offline rbean
« Reply #8 on: 23 March 2016, 22:51 »
Yeah that sounds about right .... the previous owner had the boot lid replaced in it as they reversed into something, I've already had to realign the boot myself so whoever did the work previously (as the lock has been replaced too as I have separate keys) obviously didn't do a very good job of it :(
The main problem I'm having though is that it won't close properly either the boot lid is aligned with car and the locks are aligned too
« Last Edit: 23 March 2016, 22:54 by rbean »
Offline bgbazz
  • If it aint broke...I can fix it!
« Reply #9 on: 24 March 2016, 07:06 »
Have you tried loosening the two torx screws on the fixed part which the latch engages when closed? This should allow some movement L-R and IN-OUT...just small adjustments, but could be enough to make a big difference. Don't loosen right off...just enough to allow movement when tapped. I cured a rattling bootlatch like that...it only had to go in about 3mm.
Might be worth a try.  :smiley:
Mk4 Golf TDI Estate 4Motion, remapped 1.9. Sweet runner = keeper. She is the 66th vehicle I've owned and hopefully, the last.
