Author Topic: mk2 clutch  (Read 3832 times)
Offline normski216
mk2 clutch
« on: 20 March 2016, 09:21 »
Hi all, I have a beautiful, 1989 mk2 oakie with a degrading clutch slip problem.
As the engine has had a few tweaks I'm pondering the wisdom of putting a mk3 2.0l clutch kit in over the 1.8l 16v.
My logic bring this should be able to cope with the increased output better than the standard kit.
My question is can this be done "off the shelf" ?
Thanks in advance.
Offline lemski
  • 16v
Re: mk2 clutch
« Reply #1 on: 20 March 2016, 14:47 »
Hi, youd have to change the gearbox to allow the clurch to work. But you could probally get an uprated clutch kit. Not sure though because the clutches on mk2s arent a conventional set up
Offline Simeon
Re: mk2 clutch
« Reply #2 on: 21 March 2016, 09:19 »
Sachs 16v Gti clutch kit will be fine mate, a Mk3 8v Gti cluch is not an upgrade.
Offline normski216
Re: mk2 clutch
« Reply #3 on: 21 March 2016, 12:20 »
Food for thought, cheers chaps.
Offline chrismc
Re: mk2 clutch
« Reply #4 on: 08 May 2016, 22:05 »
My old motor- bought off Tim? :laugh:
I'd swap the 8v box out & get the 2y 16v box back in there.
Whilst all apart check for evidence of leaks from either the box or crank end seal & repair as req'd
A Sachs 16v clutch kit is all it should ever need mate!
Chris
