Author Topic: Power washer incident - help and sympathy required.  (Read 4740 times)
Offline Mrparkuk
Hi All.
Washing the car this afternoon and managed to trip myself up on the hose. Upshot is a chip on my A pillar and a pressure washer water jet gouge in the rubber trim alongside. :cry:
Can anyone tell me if the strip can be replace without a visit to VW? If I can source the part I'd sooner change it myself and ease my dented pride. Any advice on the part number would be appreciated. Also is a touch up paint stick easy to acquire in carbon grey?
Current-Jan 2017 M140i, auto. Mineral Grey. ☠😈
Gone-mk7 golf Gti PP, Carbon Grey, 2015 specification, 5dr.
Offline Jimble
  • Moderator
Re: Power washer incident - help and sympathy required.
« Reply #1 on: 19 March 2016, 16:48 »
They can be replaced quite easily, they just clip behind the windscreen edge, you could remove it with something like a wallpaper scraper with some protection or ideally a trim removal tool if you have one.
Offline Mrparkuk
« Reply #2 on: 19 March 2016, 16:59 »
Thanks Jimble.
I'd hoped that was the case. Will call VW tomorrow and chase up a spare. The chip came from my watch clasp. Schoolboy error on my part - I usually remove my watch. Still don't know how I've manage to trip. same drive / equipment and wellies I've had for years.
Hadn't realise the washer could do that sort of damage. I don't have a power lance so I'd assumed damage couldn't be done. Always keep the tip well away and use it for rinsing only.
« Last Edit: 19 March 2016, 17:04 by Mrparkuk »
Offline JoeGTI
« Reply #3 on: 19 March 2016, 17:14 »
Those trims pop off easily enough. Probably relatively inexpensive to replace too. That chip is in a location too that'll barely be visible once touched up. Could have been worse!
Offline Gorocco
PP, tints, Chassis Control.
Offline kalimon
  • My other car's a van
« Reply #5 on: 19 March 2016, 17:33 »
What a nightmare, so unlucky :angry:
You could post that picture on the 'Factory Purple' thread that appeared a few months back though :whistle:
5 DR Mk 7 GTI PP
Offline Watts
« Reply #6 on: 19 March 2016, 17:43 »
Mrparkuk - jolly bad luck that! For trim removal, I find a freezer scraper quite good if you have one, nice wide plastic blade.
Try this  :smiley:
http://www.drcolourchip.co.uk/
Have you tried it? Looked good on the video but what about close up? My car's paint is chipping really well  :rolleyes: so need to decide what to do very soon.
Previously:
Offline GeoBog
« Reply #7 on: 19 March 2016, 23:40 »
You don't need any prying tool, you can pop the trim with your bare hands. Saw that when I had my windscreen replaced a year ago. Regarding the chip on the pillar, it can easily be touched up. I can also see the paint a bit scratched near the chip. That should buff out with a bit of paint polish.
2020 VW T-Cross SEL
2020 Renault Megane RS Trophy 300
2012 Fiat 500 Twinair
2007 Renault Megane 2
The two most important days in your life are the day you are born and the day you find out why.
Offline phazer
« Reply #8 on: 20 March 2016, 11:32 »
Bad luck! As others have said the paint touch in will be fine and you'll stop seeing it after a short while.
Trim wise, best I can ascertain on ETKA is that it'll cost about £12, so all in not too bad.
Offline Mrparkuk
« Reply #9 on: 20 March 2016, 13:00 »
Thanks to All for responses / advice. Very much appreciated. I'll let you know how I get on.  :smiley:
