Author Topic: Mk7 Golf - Disconnected passenger airbag key switch - now light on  (Read 6769 times)
Offline gamcqui
Hi all,
Quick question. I hardwired my dashcam and satnav into the car earlier. I had to pop off the dash 'side panel' to get access to a ground point etc, and in the process (stupidly, without thinking) I unplugged the passenger airbag key switch. Now the airbag light is lit on the dash.
What do I need to do to reset it?  :cry:
Cheers,
G
__________________
« Last Edit: 13 March 2016, 15:21 by gamcqui »
Offline AntGTD
Your best and possibly cheapest option would be to find somebody with VCDS to to clear the fault code.
2016 Mk7 Golf GTD 180(ish) Reflex Silver with loads of stuff
Offline gamcqui
Thanks.
So it takes VCDS itself to clear it? Was hoping I could get away with buying a cheap code reader.
What would be the best way of finding out if anyone in and around the North East had VCDS?
Offline gamcqui
also, does the light being on mean the airbag system won't work in a crash?
Offline itavaltalainen
Airbag system should still work as it will have likely recognised the fault as intermittent (since it detected switch again when you turned ignition on after reconnecting).
Yes it will take VCDS (or VCP or main dealer system) to reset the fault code as it is safety relevant (like most faults on brake and/or airbag system are). Look for someone on the VCDS user list on google maps, sure there is someone in the NE.
Offline mcmaddy
I'm in Houghton le spring gamcqui if that's any where near you??
Offline gamcqui
thanks for the offers guys, managed (by luck) to find a friendly garage who switched it off for free. Will remember to disconnect the battery before unplugging any sensors in future!
Offline Gtiless
So forgive me for being a little bit thick-my airbag light in the middle of the air vents in the center of the dash is on-should it not be?
Also the light at the side of it that says passenger airbag on,is on?
They were on when when I picked the car up, so I never really thought about if they should or should not be on.
They will come of for a short while after starting the car.
They do go off after a few minutes I believe.
Offline Gtiless
Cheers,Im not sure that they are going off-Ill make sure I look next time I go out in it.
