Author Topic: STOP! Engine Oil Pressure Low. Power steering went & car cut out  (Read 2851 times)
Offline NotMyName
This happened on the wife's Golf yesterday. It's a 2000 plated 1.6.
Luckily it happened in the car park she was going to park up in in town. She nursed it in to a bay after it'd cut out & went to town.
When she came to drive home later on, the engine light was still on the dash but it started up & seemed to drive ok she said.
There's plenty of oil in there - it's about 2/3 the way up the MIN-MAX on the dipstick.
Did a bit of googling which seemed to suggest it could be one of many things. Oil pump, some speed sensor to name 2.
I plugged in VagCom (still getting used to that thing) & ran a couple of scans...
On the topic of the speed sensor which we read about when researching this, this was one code...
Quote
Sunday,13,March,2016,09:54:14:47709
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 15.7.3.0 (x64)
Data version: 20151216
www.Ross-Tech.com
Mileage: 123830km-76944mi   Repair Order:
Mode 03: Emission related fault codes
Address 10 (Engine): 1 Fault Found:
P0322 - Engine Speed Sensor (G28): No Signal
Then another scan....
Quote
Sunday,13,March,2016,09:52:47:47709
www.Ross-Tech.com
Chassis Type: 1J - VW Golf/Bora IV (1998 > 2006)
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
          76
   Mileage: 123830km-76944miles
Address 01: Engine        Labels: Redir Fail!
   Part No: 036 906 034 BH
   Component:  MARELLI 4MV       3773
   Coding: 00031
   Shop #: WSC 00684
   VCID: 59B9E87FC3A32FF656-4B4E
No Faults Found
  or DTCs not supported by controller
  or a communication error occurred
Address 03: ABS Brakes        Labels: 1C0-907-37x-ABS.lbl
   Part No: 1C0 907 379 C
   Component: ABS FRONT MK60      0103
   Coding: 0001025
   Shop #: WSC 00028 615 1234567
   VCID: 2A5B67B38645746E0F-515E
1 Fault Found:
01314 - Engine Control Module
            013 - Check DTC Memory - Intermittent
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
   Part No: 6Q0 909 605 A
   Component: 0F AIRBAG VW5  01   0004
   Coding: 12358
   Shop #: WSC 00028
   VCID: 356144CF0FFB2B9692-4B1C
No fault code found.
Address 17: Instruments        Labels: 1J0-920-xx5-17.lbl
   Part No: 1J0 920 925 A
   Component: A4-KOMBIINSTR. VDO V09
   Coding: 01403
   Shop #: WSC 52580
   VCID: 275D9E87C557490610-5140
   Subsystem 1 - Part No: IMMO
   Component: IDENTNR: VWZ7Z0Y2803572
   IMMO-IDENTNR: VWZ7Z0Y2803572
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    0001
   Coding: 00006
   Shop #: WSC 00028
   VCID: 70EFB5DB30194EBE81-5140
Address 46: Central Conv.        Labels: 1J0-959-799.lbl
   Part No: 1J0 959 799 AH
   Component: 4U Zentral-SG Komf. 0001
   Coding: 04096
   Shop #: WSC 00684
   VCID: 0407E90B14A1421E55-4B02
   Subsystem 1 - Part No: 1J2959802C
   Component: 4U Tõrsteuerger. FS0002r
   Subsystem 2 - Part No: 1J2959801D
   Component: 4U Tõrsteuerger. BF0002r
   Subsystem 3 - Part No: 1J4959811C
   Component: 4U Tõrsteuerger. HL0002r
   Subsystem 4 - Part No: 1J4959812C
   Component: 4U Tõrsteuerger. HR0002r
2 Faults Found:
00953 - Interior Light Time limit
            25-10 - Unknown Switch Condition - Intermittent
00943 - Heated Exterior Mirror; Driver Side (Z4)
            35-00 -  -
Address 56: Radio        Labels: 1J0-035-18x-56.lbl
   Part No: 1J0 035 186 E
   Component:  Radio BNO         0005
   Coding: 01403
   Shop #: WSC 00028
   VCID: 275D9E87C557490610-4B1C
1 Fault Found:
00852 - Loudspeaker(s); Front
            36-10 - Open Circuit - Intermittent
End-------------------------(Elapsed Time: 05:14)--------------------------
All codes have now been cleared but haven't yet taken the car for a run.
Help very much appreciated.
On a side note.....
how can you tell if the Golf is a 16v or an 8v engine?
We bought it having been told it was a 16v.
I don't know how many of you have the MyCarCheck app for iPhone but i have the (old) version where it still gives you plenty of info.
Now when i check my own car reg it says:
Cylinders: 4
Valves/Cyl: 4
I'm assuming this is multiplied to give the 16v which my car is.
When i check the wifes reg...
Cylinders: 4
Valves/Cyl: 2
Which would be 8 if that's how you work it out.
How do you know for 100%? Just out of curiosity.
« Last Edit: 13 March 2016, 10:16 by NotMyName »
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Get us the engine code mate, should be able to tell from that
Offline NotMyName
I assume you mean for the 8v/16v thing?
Anyway it's AZD & says 77kw.
Drove it to town (about 2 mile) & then to my mothers (about 5 mile) & then back today & no lights came on.
It is making a noise from the alternator belt. My brother reckons up the adjuster needs replacing as his Golf had the same issue.
If it is this speed sensor, where is that located & do you know of a part number for it?
Offline ImIMK3
Maybe worth looking at the crankshaft sensor if the car cut out whilst driving. Had this problem with my V5
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
AZD should be the 16v variant
