Author Topic: Mk3 Anniversary alloys - which are correct??  (Read 7058 times)
Offline Audiman1
« on: 12 March 2016, 15:31 »
Hi
Still having problems getting new front brake discs to fit
Just looked at my wheels and they are BBS RS771 1JO601025E
I have just looked at Wikipedia who state that Anniverary model was fitted with RS722
Does anyone know which is correct, and what the difference is between the two??
Many thanks
Mike
Offline LR5V
Re: Mk3 Anniversary alloys - which are correct??
« Reply #1 on: 12 March 2016, 20:51 »
IIRC the easiest way to tell if you have true anni rims are if they are 7.5 inches wide and the similar ones fitted to Mk4 golfs are slightly thinner at 7 inches.
Not seen your other posts, what brakes are you running?
RXII's are known for being an problem clearing calipers, I must be lucky I have the 7" mk4 type on my valver -the calipers are close to the spokes but never had a problem.
Have you considered some hub centric spacers?
Edit: just had a look at your other post, mine are 288 discs and clear. Some people have ground back their rake calipers, not ideal but its a very small amount of metal to come off.
« Last Edit: 12 March 2016, 21:07 by LR5V »
Offline jimmydub
« Reply #2 on: 12 March 2016, 20:56 »
If it helps with your choice as far as clearing your brakes - I run 771's with standard brake set-up, not an anni but an 8v agg gti
« Last Edit: 12 March 2016, 21:01 by jimmydub »
Offline snozan
« Reply #3 on: 13 March 2016, 07:57 »
Thats the MK4 wheel
MK3 20 Jahre/20th anniversary partnumber: 1H0601025AH
http://vagparts.2am.fi/index.php?part=1H0601025AH
« Last Edit: 13 March 2016, 08:05 by snozan »
Golf MK3 GTI 16v Colour Concept - Bumble bee Edition '96
Offline Audiman1
« Reply #4 on: 14 March 2016, 12:37 »
Thanks for replies Guys, much appreciated.
will try to find a set of 7in RS722
Offline Audiman1
« Reply #5 on: 14 March 2016, 12:45 »
Thats the MK4 wheel
I have just seen a set on Ebay that show part number as 1HDG0132549, but says they are RS722
Could they still be the correct ones?
Thanks
Offline snozan
« Reply #6 on: 14 March 2016, 16:21 »
Thats the MK4 wheel
Thanks
Try a google search for that partnumber ( i did, nothing showed up).
Offline Audiman1
« Reply #7 on: 15 March 2016, 08:19 »
Thats the MK4 wheel
Thanks
Thanks, i already did that, and as you say nothing comes up.
spacers may be an easier, cheaper way, but i do like stuff to be as per original
Offline SimonG
« Reply #8 on: 17 March 2016, 06:19 »
7J for the 722 Anniversary wheels, 6.5J for the Mk4 versions.
Audiman, if you are ever in the Northampton area I have two sets, both need a refurb. You are welcome to have a look.
  Mk3 Anniversary GTI 16V, Mk2 GTI
Offline Audiman1
« Reply #9 on: 20 March 2016, 23:35 »
Thanks Simon G,
Don't get out much, so Northampton may be a bit far :smiley:
Would be interested in your sets though....any more details
You could email any pics to wklloyds@btconnect.com
Thanks for you help Guys
